GSR cluster in 5th gen
Old Jul 3, 2003 | 01:34 PM
flappy188's Avatar
flappy188
O.G. SON!
Click Here
Old Jul 3, 2003 | 09:50 PM
Outxider's Avatar
Outxider
X-Motoring
i have done it. it will look better when i get a new bezel.
heres the wiring...
for the 92-95, u need to obtain the integra cluster harness and splice it into ur stock civic wires. for the 99-00 cluster, u do the same thing. what i seen ppl done on the teggy cluster is they swap the civic plastic cover over and use bondo to smooth it up and paint it blakk so it looks stock, im kewl with all that, i just trim mines good and reuse the teggy cover. now i just need a bezel and it would look good. follow this layout for a teg cluster in a 92-95 civic.
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
on the teg right side plug for the fuel guage.. I had a pin in the 13 spot and had to move it to the 14 spot... other than that it was perfect....
Old Jul 4, 2003 | 07:13 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Sasebonian: did he use a civic gauge cluster, just put in the teg stuff?? :dunno:
Outxider: What do you mean you need a new bezel? Explain please.
Old Jul 4, 2003 | 11:23 AM
Outxider's Avatar
Outxider
X-Motoring
instead of usin the civic cover, i cut the integra cluster up, then bend up the teggy cover up so that the plastic lay kinda flat so i can fit it behind the bezel. i trim my bezel on accident hence y u can see the cut portion of the cluster. i just need another civic bezel. that whole black piece. once a new uncut bezel is in, it will look pretty much stock. cept for the small gap half inch gap on the bottom and small little gap on the sides. my friends think its kewl for whats its worth. definitely way better then my stock cluster.
Old Jul 4, 2003 | 11:40 AM
Sasebonian's Avatar
Sasebonian
'Till All R one!!
From what I remember he used the clear plastic from the civic and parts of the black plastic as well. As outxider suggested, he used some bondo or silicone to help keep it on. The entire gauge cluster is still the integra's. He didn't swap gauges or anything.
Old Jul 4, 2003 | 12:28 PM
Ferio Man's Avatar
Ferio Man
looks good outx
Old Jul 4, 2003 | 09:23 PM
westcoaststyle
hmm... read all the info on HT and it looks pretty cool.
I've got some questions out to some people out there. I may do this, it's really interesting and looks a lot better than the alternative.
Thanks for the info guys!! If you run into anything else, hook it up!!!
Old Jul 4, 2003 | 09:26 PM
Ferio Man's Avatar
Ferio Man
thatd be nice josh
ps...u get my letter yet?
Old Jul 4, 2003 | 09:36 PM
westcoaststyle
nope, today is a Federal Holiday. h:
I'll let you know diew. :chuckles:
Old Jul 4, 2003 | 09:43 PM
Ferio Man's Avatar
Ferio Man
holla back :-D
