drum brake help
how do i get the drum "cap" off so that i can access the inside of the brake? FYI i have a 95 honda civic.
essentially i plan on replacing the cylinders, as i think they have siezed, and bleeding the rears. (the fronts got bled)
make sure you're E-Brake isn't on
Get a couple of bolts that have the same thread and are the right size for the little threaded holes in the face of the drum
Work those bolts in, alternating between the two of them until you can pull the drum off the hub.
It's off!
that's it man..
hih
It's off!
that's it man..
hih
It's off!
that's it man..
hih
It's off!
that's it man..
hih
Learned something new today:bigok:
Originally posted by 165EJ1
:rofl::naughty: .............
Originally posted by Is300man
i just tried it. It doesn't work. Is there any other way to do this.. I've hit it with a hammer and tried pulling it but it will not come out.
are you talking about the grease cap? or the actual brake housing (whatever its called)
