Car won't start
Car won't start
I just replaced my alternator pulley and when I got finished installing everything my car wouldnt start. It started before I put the alternator back in, just running on the battery, and now I get no power to anything in my car. The only things that work are my hazards and my brake lights when I step on the pedal. Is there some sort of reset switch or button on the ECU because I know as a fact the battery is good, or mabey a main fuse that needs to be replaced. Please help.
Still here... sorta...
You need to check all the wiring you disconnected. You may have accidently plugged something in wrong or forgotten to plug something back in...
You may also want to check all your fuses in case you accidently shorted something while you replaced the alt.
hih
hih
