adding HID to my projectors?
Old Jul 8, 2002 | 08:02 AM
crucial Si's Avatar
crucial Si
Banned
Default adding HID to my projectors?
can that be done and does anyone have a pic of someone that does?
Old Jul 8, 2002 | 08:25 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
it has been done...i dont know how reliable or how much better it works.
the housing cant stand up to the high temperatures of a normal bulb...i dont know how it would do with HID. also the projector housing itself isnt they great to begin with...the projection of light would still be crap.
Old Jul 8, 2002 | 09:20 AM
crucial Si's Avatar
crucial Si
Banned
how hot can the HID get....i thought the output box gets hot not the lightbulb itself?
Old Jul 8, 2002 | 10:37 AM
fongaroos's Avatar
fongaroos
ive heard that HIDs actually run cooler than standard bulbs. what you said about the box running hot is probably more likely
i just helped my friend install his HIDs and they are freakin PHAT!!!
i want some so bad...
im pretty sure that with stock housings, HIDs will not melt em..but you are using aftermarket projectors...so i dont really know
but im pretty sure that HIDs run the same if not cooler than regular bulbs...
but then again im just dumb newbie
Old Jul 8, 2002 | 11:28 AM
xBaByGrLx's Avatar
xBaByGrLx
My friend did it on his Civic.. Lemme see if I can get some pics and instructions.. he has the Acura CL (I think the CL, I'll find out for sure) HID's in there.. Looks hott.
Old Jul 8, 2002 | 12:27 PM
asiandoood's Avatar
asiandoood
exactly what i meant. the stock housings will work fine.
as with the projectors...if aimed wrong with normal bulbs melts the lining of the housing (happened with mine)
also good luck on rigging a h4 conversion into the h3/h1 projector assembly.
Old Jul 8, 2002 | 12:36 PM
derf's Avatar
derf
Spec5
how do you aim them wrong to do such a thing?!?!?!
please explain
Old Jul 8, 2002 | 01:07 PM
asiandoood's Avatar
asiandoood
please explain
when i got mine a while back...i installed them without aiming them. they were pointed all the way down. the glass from the projector was touching the lining of the housing which melted the edges.
Old Jul 8, 2002 | 02:45 PM
crucial Si's Avatar
crucial Si
Banned
when i installed mine they were fine i didnt need to adjust them or anything...and i thought they made h3 hids???
Old Jul 8, 2002 | 06:14 PM
asiandoood's Avatar
asiandoood
if they did...it would be a foglamp.
