PCV 1996 civic
Old Jun 26, 2003 | 09:40 AM
s1ngle's Avatar
s1ngle
clutch slipping boost
Default PCV 1996 civic
Ok, I know topics about PCV valves have been posted before, and trust me I read all of them and still cant come to a good resolution.
I believe I have found the PCV valve on my 1996 civic EX (D16Y8). There is a hole that goes down under the intake manifold, right in the center behind the valve cover. A hose runs through, and right underneath is the valve, i think.
But anyway, I can hardly reach my arm under the intake manifold and around some tight places to touch the valve, I have no idea how i am supposed to loosen the clamp and remove it.
Anyone have an easy way of doing this??
Old Jun 26, 2003 | 12:12 PM
s1ngle's Avatar
s1ngle
i really need to find a solution to this! :thumbup:
Old Jun 26, 2003 | 12:37 PM
DSC's Avatar
DSC
Long way from home
Try jacking it up and reaching from below.
Old Jun 27, 2003 | 08:02 AM
s1ngle's Avatar
s1ngle
does anyone have experience on this? like actually have done it, and know the best way to?
Old Jun 27, 2003 | 08:06 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I don't have/nor have I ever done this, but I did find this.. might help you out:
Old Jun 27, 2003 | 08:27 AM
s1ngle's Avatar
s1ngle
not too much, you cant really see where the valve goes...
I circled the hole that the hose runs through to get down to the PCV
File Type: bmp
Old Jun 27, 2003 | 08:28 AM
s1ngle's Avatar
s1ngle
how do you put the picture right into your message...i just attached it
Old Jun 27, 2003 | 11:12 AM
westcoaststyle
you have to attach the file types that are listed to view them. BMP isn't one of them.
if it's on top, why can't you get to it?
I don't have your motor so I'm shooting in the dark here.
Old Jun 27, 2003 | 11:39 AM
s1ngle's Avatar
s1ngle
its not on top. that thing i circled is a hole, and the hose goes through this little tiny hole to the PCV valve that is located under the intake manifold. its a pain in the ass to get to.
Old Jun 27, 2003 | 05:40 PM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
well i have done it and its alot easier if you have a lift, you will have to take off your oil filter so you might as well change your oil too. after you get the oil filter off it will be right in front of you.
