T.P.S. location on a D16Y8?
Old Jun 21, 2003 | 09:24 AM
cobbcustomz's Avatar
cobbcustomz
Default T.P.S. location on a D16Y8?
I just got a zex dry kit and i am looking to tap into the TPS to control the nitrous kit. any idea what wire it is? iam looking and completely baffled. it is suppose to be like 1volt with the car in the on posistion but not running and 4.2v or above at wide open throttle I cant get those numbers tio come up anywhere
HELP!!!!!!
h: Thanks
Old Jun 21, 2003 | 09:27 AM
crucial_Si-t's Avatar
crucial_Si-t
its on the back on the intake manifold i believe.
Old Jun 21, 2003 | 10:25 AM
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
the TPS is on the throttle body.
Throttle
Position
Sensor
its not just a clever name. its actually on the TB.
Old Jun 21, 2003 | 10:48 AM
cobbcustomz
thanks i found it earlier. i just wasnt sure on the wire that i was spose to tap into.
Old Jun 21, 2003 | 11:48 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
yeah i had to tap it too for my zex kit....just get a sold T tap and you should be set
Old Jun 23, 2003 | 06:30 PM
aznxguy12's Avatar
aznxguy12
which wire did you tap into?
there are 3 wires...i tapped into the middle one.
Old Jun 24, 2003 | 12:27 PM
BoOsTzex's Avatar
BoOsTzex
middle wire...mine was black...test it by jamming the volt meter prong, into the back of the wire where it enters the clip...then with the ignition on, engine off manualy open the throttle right on the TB, you should get the 4.2 v then, also verifying thats the correct wire to tap...
Old Jun 24, 2003 | 07:05 PM
aznxguy12's Avatar
aznxguy12
Default RE & F/S
Well i already tapped the middle red wire on my car b4 i read ur response. Well it works, I put it on the ON position then, press on the gas pedal to WOT, then it clicks.
Pretty cool, i got the Dry Kit and Purge Kit.
Got an extra pressure gauage, spark plugs, and Ejector Air Amplifer, all brand NEW if anyone needs.
Old Jun 24, 2003 | 07:26 PM
BoOsTzex's Avatar
BoOsTzex
I dont have much $$ right now, but I do want a pressure gauge, at some point, How much do u want for it? I might be able to scratch up some cash for a good deal??
Old Jun 24, 2003 | 07:47 PM
aznxguy12's Avatar
aznxguy12
Default re
they go for $50 on zex, let's say $40 shipped via USPS 2-3 days?
