throttle body?
Old Jul 5, 2002 | 01:58 PM
dicivicHB's Avatar
dicivicHB
...on Christ's Team...
Default throttle body?
What's a throttle body, and what does it do? I found a performance part that supposedly adds up to 20 hp by lifting the throttle body.
Old Jul 5, 2002 | 05:03 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Sadly, this should definitely be a question posted here: https://www.honda-acura.net/forums/s...&threadid=3298
This is a really basic question and I'm actually scratching my head cause of its simplicity... Anyhow, the throttle body is what your intake tube (not manifold) connects to. It's round and your throttle cable runs to it. It has a plate that rotates with the movement of the throttle cable called the butterfly. The throttle body is what controls how much air intake your engine gets.
That's the super simple answer. You'll probably get a better, more detailed answer if you post to the above link.
Hope it helps.
Old Jul 5, 2002 | 06:56 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
The throttle body is basically where the air from the intake goes in (and then into the intake manifold) and it has a system of "butterflies" which open and close these tubes via the throttle cable (which moves when you press your gas pedal) and depending how much air is let in the engine will rev higher.
Old Jul 5, 2002 | 08:00 PM
westcoaststyle
So, technically, the phrase "giving it gas" is not really the case - you're actually giving it air.
Just thought I'd throw that in there. haha
Old Jul 6, 2002 | 10:13 AM
skubb's Avatar
skubb
not that TLC sh!t either
you're doing both
estoner102
92+ Civic/EL & Del Sol
Apr 3, 2004 06:39 PM
LateApex
Oct 22, 2003 01:43 PM
jermothedrunk
2
Jul 24, 2002 10:58 AM
