what fuse would this be....
BOOM goes the dynamite!
i was driving and my speedo and tach died. then i realized that my turn signals don't work. don't even blink. my hazards (4-ways) don't work either. but the dash still lights up, the corners, headlights, and tail lights still work. but i can't figured what fuse blew (i'm guessing it's a fuse somewhere). anyone know? thanks.
I had same happen to me......usually its the wiring behind the gauges....if not you blew a fuse under your dash....you should have the chart that tells you......if not check each one and find the one(s) that blew.
well, i found the hazard fuse which was blown. that fixed my hazards. but the gauge cluster still doesn't work (along with the clock). but the radio works. and when i turn my key to "on" it doesn't do the long beeps, just the short ones. any more ideas?
Originally posted by fish
this will sound stupid but check the fuse for the reverse lights i blew that fuse and the same problem you are having happened to me.
well, i went and look more today. i think it was a combo of things. the reverse lights fuse was blown (though, when i first checked it, it wasn't). so i think it blew after i fixed the hazard lights fuse. i :dunno: i'm running out of a fuses, so i need to go buy some more. but everything works (for now). thanks.
