installing a/f and boost guage.
Old May 23, 2003 | 09:04 PM
crucial v.2.2's Avatar
crucial v.2.2
Banned
Originally posted by CivicSiRacer
The A/F meter in a Honda is useless basically I don't know why I keep mine in my car
either way..i got it for $20 and i really need to know if im running to lean at the time of WOT.
Old May 23, 2003 | 11:02 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
well thats the only time you will get a accurate reading is when you are at WOT because it should read "rich" ,...and if you dont go to your ECU then go to the white wire (i think but i can check for you if you want) on your o2,...i went to the o2 on both of my hatchbacks because im running the OBD2 to OBD1 in both cars,...im suppose to be getting a good deal on a wideband o2 so my A/F will be more accurate
Old May 24, 2003 | 07:07 AM
crucial v.2.2
Banned
Originally posted by ManTiS
a/f
purple ---> thick white wire by ECU
looked at the ecu wiring..i dont see a white wire that stands out as being "thinker" than the rest
Old May 24, 2003 | 07:17 AM
Outxider's Avatar
Outxider
X-Motoring
just tap into the white wire on ur o2 sensor.
Old May 24, 2003 | 07:38 AM
crucial v.2.2
Banned
FINE
Old May 24, 2003 | 09:24 AM
crucial v.2.2
Banned
where can i splice into to get the ignition power??? i cant find my testlight can it go to the fuse box?
Old May 24, 2003 | 10:00 AM
Brad's Avatar
Brad
wooo nascar!
im sure theres a fuse for the ignition.. that should work.
Old May 24, 2003 | 12:33 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
how much shit you got powered up to your fuse box crucial??? if not much and if your radio fuse is free then just tap it into your radio fuse in your fuse box,...all you need is a fuse that is hot when the key is in the on position,..or you can splice it into the hot wire for your cigarette socket
Old May 24, 2003 | 12:36 PM
ManTiS's Avatar
ManTiS
NinJA
find that test light ... or another one is like $5
Old May 24, 2003 | 01:59 PM
crucial v.2.2
Banned
i have the boost gauge working now..just need to wire up the light when i turn on the parking lights..no biggie.
i am having a problem with the a/f though..i dont think i have a good ground...i have the purple wire to the white wire on the o2..ill **** with it later tonight..i have a 15s to go to..thanks..late
