switched to 89
Old May 21, 2003 | 01:32 PM
oc_civic's Avatar
oc_civic
mcc racing
i use at least 94, less prone to detonation on juice
Old May 21, 2003 | 01:37 PM
crucial Si's Avatar
crucial Si
Banned
yeah..but your different
i use 93 since on boost.
Old May 21, 2003 | 03:48 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Yeah although 89 solves your problem for now, the engine should usually only need 87 to run correctly so I would get the motor checked out. Is your timing advanced? Get a valve adjustment if you are at one of the tune up intervals also. :thumbup:
Old May 21, 2003 | 03:52 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
:werd:
the dohc vtec engines pretty much require 91+
most other honda engines run fine on 87
Old May 21, 2003 | 04:43 PM
Nelson's Avatar
Nelson
Administrator
Originally posted by 18secFerio
:werd:
Yeap! That and I'm pretty sure my motor was used to a higher octane back when it was chillin' in JDM land. I had to make sure I'd be at least close to it. 94 Sunoco :goodjob:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old May 21, 2003 | 04:47 PM
19.3secS2K's Avatar
19.3secS2K
yeah, my '90 accord ex required 89, but that was pre-vtec days.
the latest odysseys use 91 also, unless you want a tad less power.
I think the AV6 (at least the 6th gen) can get away with 87, but I :dunno: what my dad uses for it.
Old May 21, 2003 | 05:55 PM
Jessica's Avatar
Jessica
ch1x0r
thanks :thumbup: i'll get that checked out.
