gsr swap
Old May 20, 2003 | 09:08 AM
ssbluegsr's Avatar
ssbluegsr
Default gsr swap
I recently totalled my GSR and I am throwing the motor and trans in a 96+ hatch. What will I need to do that. I know I need motor mounts.
Old May 20, 2003 | 09:10 AM
Tirod's Avatar
Tirod
tools :chuckles:
Old May 20, 2003 | 09:14 AM
madlow's Avatar
madlow
If the GSR is 94+ then it will bolt right in with no troubles using the GSR mounts. And you will have to run a vtec wire which is very easy.
Old May 20, 2003 | 09:18 AM
ssbluegsr's Avatar
ssbluegsr
Thats cool the motor mounts will work. What wire has to be run. What about the rear disc swap, does that bolt right up?
Old May 20, 2003 | 09:29 AM
spooncivicb16b's Avatar
spooncivicb16b
i'm pretty sure it does. if not you could try and get the 99-00 si discs
Old May 20, 2003 | 09:58 AM
Grifter's Avatar
Grifter
you will need wire harness
dont forget ecu
integra lcas will not fit 96+ civics
how is it totaled if you can salvage the engine and rear suspension?
Old May 20, 2003 | 10:02 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
You'll use your the dx harness and modify and lengthen the plugs.
You'll also need the 99' Si rear bracket and driver's upper bracket.
Old May 20, 2003 | 11:22 PM
dantastic's Avatar
dantastic
cx power!
:werd: its easiest to adapt the stock harness to the new motor. u need those mounts, but u'll reuse everything else: linkage, axles, fuel pump and feed line to the fuel rail.
