valve adj
Old May 14, 2003 | 09:23 AM
4-banging's Avatar
4-banging
Default valve adj
plannig to do a valve adjustment (B16) ina couple of weeks. should I use a honda factory head gasket or go for some other brand?
please list others:
Old May 14, 2003 | 09:54 AM
cvc2k's Avatar
cvc2k
You don't need to replace head gasket to do valve adjustment.
You should be able to reuse the valve cover seal unless it is torn.
You do need hondabond liquid gasket though... for a few places on the seal. Remember to check idle rpm and timing after the adjustment.
Old May 14, 2003 | 10:23 AM
4-banging's Avatar
4-banging
really, even though it's going to be 30K miles since the last adjustment? I'll prolly replace it anyways just to be on the safe side.
Old May 14, 2003 | 11:21 AM
oc_civic's Avatar
oc_civic
mcc racing
i agree that unless damaged replacing is unneeded
Old May 14, 2003 | 11:58 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Dude.. wtf?? :eh:
Head gasket has NOTHING to do with valve adjustment. You only have to remove the valve cover to do the adjustment. If you think you need to, replace the valve cover seal and the spark plug seals (on the valve cover)... that's it.
I read that like 5 times I was so confused :loco:
Old May 14, 2003 | 01:17 PM
4-banging's Avatar
4-banging
Originally posted by westcoaststyle
Dude.. wtf?? :eh:
sorry, i was using the wrong terminology
I'll replace the valve cover seal & spark plug seal :thumbup:
thanx
Old May 14, 2003 | 01:23 PM
westcoaststyle
h:
Valve cover seal != head gasket :chuckles:
Good luck man.
