Dx/ex/lx?
Old May 14, 2003 | 01:11 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
4th gen 88-91
5th gen 92-95
6th gen 96-00
7th gen 01-now
don't remember what 1st, 2nd, and 3dr gen years were and too lazy to look it up :fawk:
Old May 14, 2003 | 01:45 PM
Kabooki's Avatar
Kabooki
thnx
Old May 14, 2003 | 03:28 PM
str8edgexx's Avatar
str8edgexx
Originally posted by LocaL raCer
just a bit of info.. there are 5th gen LX coupes. they are few and far between tho.
I have never heard of/read about/seen one of them in my entire life. Are you sure about that? Can any of you 5th gen guys confirm that?
Old May 14, 2003 | 05:15 PM
Cashis EG8's Avatar
Cashis EG8
I've never heard of an LX coupe either in the 5th gen. Was it just a rebadged DX with power door locks and windows?
Old May 14, 2003 | 05:45 PM
94civicEX's Avatar
94civicEX
I got worms.
http://performancesupply.com/civic92-95.htm
1992-1995
Engine
Type
Aluminum Block and Head
Valvetrain
SOHC 4 valve/cyl.
Displacement
97 cu in./1590cc (EX, Si)
91.1 cu in/1493cc (DX, LX, VX, CX)
Bore x Stroke
2.95 x 3.54 in./75.0 x 90.0 mm (EX, Si)
2.95 x 3.33 in./75.0 x 84.5 mm (DX, LX, VX, CX)
Compression Ratio
9.2:1 (EX, Si, DX, LX)
9.3:1 (VX)
9.1:1 (CX)
Horsepower (SAE)
125 bhp @ 6600 rpm (EX, Si)
102 bhp @ 5900 rpm (DX, LX)
92 bhp @ 5500 rpm (VX)
70 bhp @ 5000 rpm (CX)
Bhp/Liter
78.1 (EX, Si)
68.0 (DX, LX)
61.3 (VX)
46.7 (CX)
Torque
106 lb-ft @ 5200 rpm (EX, Si)
98 lb-ft @ 5000 rpm (DX, LX)
97 lb-ft @ 4500 rpm (VX)
91 lb-ft @ 2000 rpm (CX)
Maximum engine speed
7200 rpm (EX, Si)
Fuel injection
Elect. sequential port
Fuel
Unleaded, 87 pump oct.
Chassis & Body
Layout
Front engine/front wheel drive
Body/Frame
Unit Steel
Gross Vehicle Weight Rating
Coupe
DX M/T: 3,245 lbs
DX A/T: 3,315 lbs
EX: 3,490 lbs (Including EX option package)
Hatchback
CX, VX: 3,055 lbs
DX M/T: 3,090 lbs
DX A/T: 3,210 lbs
Si: 3,270 lbs
Si w/ ABS: 3,305 lbs
Sedan
DX M/T, LX M/T: 3,245 lbs
LX M/T w/ ABS: 3,405 lbs
DX A/T, LX A/T: 3,315 lbs
LX A/T w/ ABS: 3,405 lbs
EX: 3,490 lbs
Brakes
Front
10.3 in vented disc
Rear
9.4 in disc w/ABS (EX Sedan, Si Hatchback, EXa Coupe, Available on LX)
7.9 in drums (DX, LX)
7.1 in drums (VX, CX)
Assist type
vacuum
Wheels
Pressed steel, 14 x 5J (EX, Si)
Pressed steel, 13 x 5 (DX, LX, CX)
Alloy, 13 x 4.5 (VX)
Tires
P185/60R-14 82H (EX Coupe, Si)
P175/65R-14 (EX Sedan)
P175/70R-13 (DX)
P165/70R-13 (VX, CX)
Steering
Rack & Pinion
Power Assist (EX, Si, LX, DX Sedan, DX Coupe w/ Auto transmission) Manual (DX Coupe w/Manual transmission)
Overall ratio
17.5:1 (Power)
19.0:1 (Manual)
Turns, lock to lock
3.58 (Power)
3.88 (Manual)
Suspension
Front
Upper A-arms, lower L-arms, coil springs, tube shocks
21.0 mm anti-roll bar (EX, Si, LX)
Rear
Trailing arms on upper & lower lateral links, compensating links, coil springs, tube shocks
13.0 mm anti-roll bar (EX Sedan)
Acceleration (EX)
0-30 mph
2.9 secs
0-40 mph
4.6 secs
0-50 mph
6.5 secs
0-60 mph
9.1 secs
0-70 mph
12.1 secs
0-80 mph
15.5 secs
0-90 mph
21.8 secs
0-100 ft
3.4 secs
0-200 ft
9.1 secs
0-1320 ft (1/4 mile)
16.8 secs @ 82.3 mph
Standard Equipment, Civic Sedans
DX Sedan includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), Power Steering, 4-Wheel Double Wishbone Suspension, 5-Speed Manual or 4-Speed Automatic Transmission, P175/70 R13 All Season Tires, Coin Box, Beverage Holder, Fold-Down Rear Seatback with Lock, Adjustable Front Seat Belt Anchors, Dual Manual Remote-Operated Mirrors
LX Sedan adds:
Power Windows, Mirrors and Door Locks, Cruise Control, Tachometer, Center Console Armrest with Storage Compartment, AM/FM High Power Stereo Cassette with 4 Speakers, Quartz Digital Clock, Cargo Area Light, Front Stabilizer Bar, 14" Wheels with Full Covers, P175/65 R14 All-Season Tires, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
EX Sedan adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Anti-Lock Braking System (ABS), 4-Wheel Disc Brakes, Rear Stabilizer Bar, Air Conditioning, Power Moonroof
Standard Equipment, Civic Coupes
DX Coupe includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), 5-Speed Manual or 4-Speed Automatic Transmission, Power Rack and Pinion Steering (AT only) Power-Assisted Front Disc/Rear Drum Brakes, P175/70 R13 All Season Tires, Beverage Holder, 2-Speed/Intermittent Windshield Wipers, Fold-Down Rear Seatback with Lock, Dual Manual Remote-Operated Mirrors
EX Coupe adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Power Rack-and-Pinion Steering, Front Stabilizer Bar, 14" Wheels with Full Covers, P185/60 R14 82H All-Season Tires, Power Moonroof w/ Tilt Feature, Body-Colored Dual Power Mirrors, Power Windows and Door Locks, Cruise Control, AM/FM High-Power Stereo Cassette with 6 Speakers ('94 and '95 models only), Quartz Digital Clock, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
Standard Equipment, Civic Hatchbacks
All Civic Hatchbacks Include:
Dual Airbags (SRS), Multi-Point Programmed Fuel Injection (PGM-FI) Engine, 5-Speed Manual Transmission, 4-Wheel Double Wishbone Suspension, Beverage Holder, Split Fold-Down Rear Seatback, Coin Box, Two-Piece Hatch
CX Hatchback Key Features:
1.5 Liter, 70-hp, 8-Valve Engine, P165/70 R13 All-Season Tires, Rear Window Defroster with Timer, Hatch-Open Warning Light, Remote Fuel Filler Door Release, Remote Hatch Release, Passenger Assist Handle, Dual Manual Remote-Operated Mirrors
DX Hatchback Key Features:
1.5 Liter, 102-hp, 16-Valve Engine, Available 4-Speed Automatic Transmission with Power Steering, P175/70 R13 All-Season Tires, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/Intermittent Windshield Wipers, Rear Window Wiper/Washer, Remote Fuel Filler Door Release, Remote Hatch Release, Dual Manual Remote-Operated Mirrors
VX Hatchback Key Features:
1.5 Liter, 92-hp, 16-Valve VTEC-E Engine, Lightweight 13" Alloy Wheels, P165/70 R13 All-Season Tires, Chin Spoiler, Tachometer, Dual Manual Remote-Operated Mirrors
Si Hatchback Key Features:
1.6 Liter, 125-hp, 16-Valve VTEC Engine, Power Steering, 4-Wheel Disc Brakes, 14" Wheels with Full Wheel Covers, P185/60 R14 All-Season Tires, Power Moonroof with Tilt Feature, AM/FM High-Power Stereo Cassette, Cruise Control, Rear Window Wiper/ Washer, Tachometer, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/ Intermittent Windshield Wipers, Body-Colored Dual Power Mirrors
99 Integra GSR
06 TSX
duck squad member #00003
Old May 14, 2003 | 05:46 PM
94civicEX's Avatar
94civicEX
I got worms.
http://performancesupply.com/civic96-00.htm
1996-1999 Excluding 1999-2000 Si
Engine
Type
Valvetrain
SOHC 4 valve/cyl.
Displacement
97 cu in./1590cc
Bore x Stroke
Compression Ratio
9.6:1 (EX)
9.4:1 (DX, HX, LX)
Horsepower (SAE)
127 bhp @ 6600 rpm (EX)
115 bhp @ 6200 rpm (HX)
106 bhp @ 6200 rpm (DX, LX)
Bhp/Liter
79.9 (EX)
72.3 (HX)
66.7 (DX, LX)
Torque
107 lb-ft @ 5500 rpm (EX)
104 lb-ft @ 5400 rpm (HX)
103 lb-ft @ 4600 rpm (DX, LX)
7000 rpm (EX)
Fuel injection
Fuel
Chassis & Body
Layout
Body/Frame
Unit Steel
Brakes
Front
10.3 in vented disks
Rear
7.9 in drums
Assist type
vacuum
Total swept area
267 sq in.
Swept area/ton
196 sq in.
Wheels
Pressed steel, 14 x 5J (EX, LX)
Alloy, 14 x 5J(?) (HX)
Pressed Steel, 13 x ?? (DX)
Tires
Firestone FR680, P185/65R-14 82H (EX, LX, HX)
P175/70R-13 82S (DX)
Steering
Rack & Pinion
Power Assist (EX, LX, DX Sedan, DX Coupe w/ Auto transmission) Manual (DX Coupe w/Manual transmission)
Overall ratio
17.7:1
Turns, lock to lock
3.6
Turning circle
32.8 ft
Suspension
Front
22.0 mm anti-roll bar (EX, HX, LX)
Rear
Acceleration (EX)
0-30 mph
2.9 secs
0-40 mph
4.6 secs
0-50 mph
6.5 secs
0-60 mph
9.1 secs
0-70 mph
12.1 secs
0-80 mph
15.5 secs
0-90 mph
21.8 secs
0-100 ft
3.4 secs
0-200 ft
9.1 secs
DX Sedan includes
Dual Airbags, 1.6 Liter, 106-hp, 16 valve engine with PGM-FI, Power Rack and Pinion Steering, 4-Wheel Double Wishbone Suspension, 5-Speed Manual or Available 4-Speed Automatic, Adjustable Steering Column, Power-Assisted Front Disc/Rear Drum Brakes, Audio Plus (tm) AM/FM High-Power Stereo with Clock, Coin Box, Beverage Holder, 60/40 Split Fold-down Rear Seatback with Lock, Adjustable Front Seat Belt Anchors, Dual Manual Remote-Operated Mirrors, Low-Fuel Warning Light, Headlights-On Reminder, Rear Seat Heater Ducts, Child-Proof Rear Door Locks, Dual Vanity Mirrors, Rear Window Defroster with Timer, Remote Fuel Filler Door Release, Remote Trunk Release with Lock, Maintenance Interval Indicator, Low-Oil Warning Light, Trunk-Open Warning Light, Trip Odometer, Driver's Footrest, 2-Speed/Intermittent Windshield Wipers, Reclining Front Seatbacks, Seatback Pocket, Adjustible Front Head Restraints, P175/70 R13 82S All-Season Tires
LX Sedan adds
Dual Power Mirrors, Door Locks and Windows with Auto-Down Driver's Window, Front Stabilizer Bar, Cruise Control, Tachometer, Front Center Armrest with Storage Compartment, Cargo Area Light, Available Anti-Lock Braking System (ABS), Door Pocket Storage Bins, 14" Wheels with Full Wheel Covers, P185/65 R14 85S All-Season Tires
EX Sedan adds
127-hp, 16-Valve VTEC Engine with PGM-FI, Anti-Lock Braking System, Air Conditioning, Power Moonroof with Tilt Feature, Remote Entry System, Body-Colored Dual Power Mirrors, Body-Colored Side Moulding
DX Coupe includes
Dual Airbags, 1.6 Liter, 106-hp, 16-Valve Engine with PGM-FI, 5-Speed Manual or Available 4-Speed Automatic Transmission, 4-Wheel Double Wishbone Suspension, Power Rack and Pinion Steering (AT only), Adjustable Steering Column, Power-Assisted Front Disc/Rear Drum Brakes, Audio Plus (tm) AM/FM High-Power Stereo with Clock, Coin Box, Front and Rear Beverage Holders, Dual Manual Remote Operated Mirrors, 2-Speed/Intermittent Windshield Wipers, Remote Trunk Release with Lock, Remote Fuel Filler Door Release, 60/40 Fold-Down Rear Seatback with Lock, Low-Fuel Warning Light, Dual Vanity Mirrors, Reclining Front Seatback, Seatback Pocket, Adjustable Front Head Restraints, Rear Window Defroster with Timer, Driver's Footrest, Trip Odometer, Maintenance Interval Indicator, Low-Oil Warning Light, Headlights-On Reminder, Trunk-Open Warning Light, P175/70 R13 82S All-Season Tires
HX Coupe adds
115-hp, 16-Valve VTEC-E Engine with PGM-FI, Available CVT, Dual Power Mirrors, Door Locks and Windows with Auto-Down Driver's Window, Power Rack-and-Pinion Steering, Tachometer, Front Stabilizer Bar, Front Center Armrest with Storage Compartment, Door Pocket Storage Bins, Cargo Area Light, 14" Alloy Wheels, P185/65 R14 85S All-Season Tires
EX Coupe adds
127-hp, 16-Valve VTEC Engine with PGM-FI, 5-Speed Manual or 4-Speed Automatic Transmission, Available Anit-Lock Braking System, Power Moonroof with Tilt-Feature, Cruise Control, AudioPlus (tm) AM/FM High-Power Stereo with Clock and 6 Speakers, Remote Entry System, Air Conditioning, Body-Colored Dual Power Mirrors, Body-Colored Side Moulding, 14" Wheels with Full Wheel Covers
99 Integra GSR
06 TSX
Old May 14, 2003 | 05:52 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
Ex = no rear sway bar (only Si)
ex sedans have a rear sway bar. i have one.
and my 92 ex have rear discs.
Old May 15, 2003 | 02:19 AM
LocaL raCer's Avatar
LocaL raCer
R.I.P. Kato-san
i'm sorry that since you haven't heard of it, it doesn't exist and i'm a liar.
i believe so.
Dubsters mom used to have a OMFG a 5th Gen LX coupe. so if you guys still dun wanna take my word, ask him. god, i hope when i get my civic you guys are gonna be a little er.
Old May 15, 2003 | 07:27 AM
94civicEX's Avatar
94civicEX
I got worms.
i believe so.
Read my shit I posted assholes, it's actually useful, not just jibberish h:.
LX Sedan adds:
I believe that it came in the Sedan model, not sure on the Coupe model 5th Gen LX.
99 Integra GSR
06 TSX
Old May 15, 2003 | 08:31 AM
Cashis EG8's Avatar
Cashis EG8
:rofl: Sorry that just cracks me up
