timing gun choice???
Old May 10, 2003 | 09:32 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default timing gun choice???
i know there are many types of timing guns and the ones that i am looking to get are those that have the digital RPM meter display. however, i couldn't find any one that i like from pepboys. so are there any suggestions?
also, when you flash the timing belt and see the lines... how do you know how many degrees it is being advanced or retarded? perhaps if someone can show me a site on how a timing gun works.. that would be great.
if i were to adjust my own timing belt... what tools would i need? and any "how to" sites on that as well? thanks.
Old May 12, 2003 | 12:12 AM
frank's Avatar
frank
frank from canada
to answer your middle question, the specs are conveniently located on the underside of the hood... or at least mine was...
Old May 12, 2003 | 07:19 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Here's the one I have.
http://www.sears.com/sr/product/summ...id=00921023000
It's a craftsman and I like it. They have 2, one that has an advance on it and that doesn't (that's the one that does). You really can't see in the picutre, but on the back of that light, there is a small knob that you turn to advance or retard the timing. If you don't have the knob, you just have to use the provided markings from the OE manufacturer.
How a timing light works is by attaching to the #1 spark plug wire and flashing when a spark goes through it. You aim the gun down at the crank pully on the driver side of the engine. There are three marks on the pully like this | | | and a small marker built into the timing belt cover. Factory advance is 16 degrees (for a B18C1 I believe, don't quote me, it's all really relative), so if the middle marker on the crank pulley and the one on the cover line up, your right on the money. Honda provides a 2 degree advance and retard on the crank pulley (the other two |). To advance the ignition, you loosen the distriubtor bolts and rotate the distributor. I believe forward (towards the front) is advance and back towards the firewall is retard, but I can't remember for sure). Also, the service manaual also recommends jumping the computer into diagnostic mode (like you would to check for a code) before advancing the ignition. I've also been told that's not nessicary, but it take 25 seconds so I'd do it. If you have a timing lights with the knob, you can set it for 2 degree's advance and then just line up the center markers again (nessicary if the crank pulley only has 1). Seeya.
Old May 13, 2003 | 03:07 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
Default Re: What's up?
Andy... thank you soo much! :thumbup: if only if craftsman made one with digital RPM meter on it...
Old May 13, 2003 | 03:21 PM
SRT_Andy's Avatar
SRT_Andy
I had one made from MATCO tools that I used when I was a Volvo tech. It had timing advance and retard with a digital readout as well. Even though it was $300, it was definitely worth it.
Old May 13, 2003 | 03:29 PM
tokyoracer's Avatar
tokyoracer
got JDM milk???
do you happen to have the model # for it? cuz i saw one similar to the one you said at kragen for $134.99. just want to make sure if it is similar
