Need help on GLOW GAUGE FACE
Old May 10, 2003 | 07:56 PM
zyzyx6969's Avatar
zyzyx6969
EG9
Default Need help on GLOW GAUGE FACE
I have a 95 Civic, just bought a set of glow gauges (used), dunno how to install it ! If you guyz knew or already done it, please help me out ! thanks alot !!!
Old May 11, 2003 | 07:15 AM
MrJasey's Avatar
MrJasey
uh just take out the gauge cluster and use a multimeter to find the right wires if u dont have the manual. solder the wires, put back in the cluster and the bezely thingy and u are done...do u have any specific problems?? i used a power from one of the big harnesses on the back of the cluster and grounded it through a screw i think...it was a while ago lol. PM or IM me if u have any questions....or need pictures...i can plop out my cluster and snap some digi shots and email them to u if u really need them
Old May 11, 2003 | 12:49 PM
94civicEX's Avatar
94civicEX
I got worms.
Check this out: http://www.performancesupply.com/howindiglo.htm
They've been known to catch fire though :chuckles:.
99 Integra GSR
06 TSX
duck squad member #00003
Old May 11, 2003 | 01:28 PM
SRT_Andy's Avatar
SRT_Andy
Talk about getting flamed! :thumbup:
Old May 11, 2003 | 01:44 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
all i did was have the wire tap into where the parking lights fuse is, and have it grounded to a screw under the dash. didn't solder anything. the only tricky part is the temp/gas gauge. i slightly bent mine to get it over the needles.
Old May 11, 2003 | 07:04 PM
MrJasey's Avatar
MrJasey
solder is the best way...wire taps can come loose or not crimp the wire all the way and then u will be annoyed...i mean it takes like five more seconds to solder the wires, not a big deal
Old May 11, 2003 | 10:08 PM
flipped cracka
i mean, i just stuck it right at the fuse, so it's not coming loose. put it in the spot where the fuse goes, then shoved the fuse in. everything still works, so that works for me. :dunno:
Old May 12, 2003 | 09:29 AM
onebadassdx's Avatar
onebadassdx
your lucky you just bent yours...i completely snapped my fuel needle off.. now its eternally stuck on E. haha, oh well at least my gas light still works
Old May 12, 2003 | 09:34 AM
flipped cracka
i mean, i bent the gauges. but it was my second time installing them. this first time around, i thought i could just pull the needles off, but that was no good. i broke the fuel and temp gauges that way, and the tach and speedo were off. 92-95 don't have gas lights, so that sucked.
