Maintenance Question
Old May 8, 2003 | 10:06 AM
str8edgexx's Avatar
str8edgexx
Default Maintenance Question
My car just hit 30k the other day, so this weekend, I'm gonna do the required 30k maintenance. According to my books, it says I should do:
Oil/Filter Change
Top off all fluids
Change Spark Plugs
Inspect brakes
Inspect Drive Belts
Visually Inspect a number of components
My question is, is there anything else I should do? I was thinking about replacing the pads on the brakes. Should I change the wires too (since I'm changing the plugs)? What about the distributor cap? What about the fuel filter? Any input would be appreciated.
Old May 8, 2003 | 10:14 AM
Hondaman's Avatar
Hondaman
Black Pearl
I would do fuel filter and air filter as well. Don't worry about pads, wires or distributor cap. Save those for the 60000 mile maintenance.
Old May 8, 2003 | 10:17 AM
str8edgexx's Avatar
str8edgexx
the air filter is a K&N with only about 15k on it, so that is safe
Old May 8, 2003 | 03:14 PM
Tirod's Avatar
Tirod
what car is this? any plans on aftermarket parts on those items? i'd go that route at least (wires, brakes, etc).. :thumbup:
Old May 9, 2003 | 06:04 AM
str8edgexx's Avatar
str8edgexx
its a '98 Lx....no real big plans for any aftermarket parts...this is my commuter car back and forth to work, and its an auto, so its not worth doing much to.
Old May 9, 2003 | 08:39 AM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
Isn't a valve adjustment needed at 30k?
Old May 9, 2003 | 10:51 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You could do the valves, it couldn't hurt. I wouldn't worry about the brakes either, they're easy to figure out when they need changing.
I wouldn't change the cap or rotor unless you're experiencing problems with them. The plugs, sure, but other than that...
HIH
Old May 9, 2003 | 04:24 PM
str8edgexx's Avatar
str8edgexx
ok, cool...thanks. Are the valves hard to adjust? I've never done it before. Would it be something I could do with my Helms manual, or should I leave it to the pros? I'm pretty competant
Old May 9, 2003 | 05:43 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
http://www.angelfire.com/biz7/aiperf...djustment.html
Old May 9, 2003 | 06:15 PM
str8edgexx's Avatar
str8edgexx
cool...thanks for the link :thumbup:
