hmm... new fuel pump.... still no go?
cx power!
Location: berkeley, ca --> la, ca representin' tha 510&626
hey folks,
anyone here running a 225lph on their b-series motor? are you running a fpr too?
my motor was running way lean b/c i had a strained cx fuel pump. i just popped in a brand spanking new 225lph bbk. it ran swell. for like 30 min. now its bogging and the exhaust smells like i spilled gas all over the car.
i checked my plugs: 3 were wet with fuel, 1 (#1) was hella sooty (black almost). i thought the stock fpr might have busted, so i popped my stock cx one on (good thing i still have my cx motor in my back yard ) i also picked up some plugs. still no go.
gonna go buy a fpr and guage.... anyone have any input?
Black Pearl
Maybe you have a plugged return line, or it may have gotten kinked somehow. With the higher volume pump, it is getting way too much fuel and can't return the unused to the fuel tank. A guage will help you determine if that is the problem.
cx power!
arhg.... just checked... the return line at the pump housing looked a bit kinked. the clamp was at the tip of the fitting. changed the clamped, and checked the line at the fpr too. still no go. looks like ima get that b&m fpr and guage
cx power!
yea.. i held my hand next to my muffler, and it smelled/felt like i spilled gas on it. should gone with the 190lph h: should get a fpr and guage anyway
Black Pearl
Originally posted by EG_Oto
you'll be ok... just clean the plugs once u get ur setting right. goodluck
Still here... sorta...
I'm running the exact same pump as he is (he got his from me ) with the B&M FPR, gauge and new fuel line at 9.5:1 and I run just a little rich. I was running rich even before the pump, but I have a lot more control over the PSI and it doesn't lean out on me when I punch it.
I don't think the pump is the problem, once you get the FPR, gauge and line, you'll be golden.
One of the original OG's
definately just get a fuel guage. The pump is not the problem. I have a holley 255lph pump and it works great. It's definately your FPR. I would get the AEM rail with the FPR included. I have an extra B16A FPR if your interested.
