93 civic hb gas tank leak
Old 05-05-2003, 02:59 PM
tech1250
tech1250's Avatar
Default 93 civic hb gas tank leak
I have a small gas leak coming from the gas tank drain bolt on the lower left side of the gas tank.Its a very slow leak, in the morning there will be a 2.5inch greasy/gassy spot on the ground.Just wondering what would be the best way to repair this?.Should I try tightening it up or just get a new drain bolt/washer and install it after running the car to near bone dry empty?Safety here is my main concern around any gas leaks.Any suggestions would be appreciated.The honda manual shows a picture of the drain bolt on page 11-131 if anyone has one.
tech125
Old 05-05-2003, 04:24 PM
Bakeoff
wooooo woooooooooo
Bakeoff's Avatar
I'd just go get a new one from honda, with the O ring.
BUT, make sure you have pleanty of cigarettes, and possibly a torch handy before you crack that bad boy open! WAIT, NO!!!
Seriously, once you get the O ring replaced, it should be dandy, but make sure you torque it to spec. Don't need to strip it out and have to rethread it.
Old 05-05-2003, 05:10 PM
tech1250
tech1250's Avatar
Just ordered a new gas tank drain plug and washer for $2.
Just for kicks i asked the service department how much
they would charge to replace the bolt/washer, they said $92!
because they had to drain the tank.I said how much if i bring
the tank in empty? They came back with $46! they have to
perform a leak test.Im not paying the dealer a half hour labor to remove and re-install one bolt, ill do it myself.....
Old 05-14-2003, 02:52 PM
tech1250
tech1250's Avatar
Default follow up
Replaced gas tank drain plug and o-ring/washer.The old washer
was pretty much desintegrated from road salt even though
I had to remove undercoating from the old bolt to remove it.
No more leakage.......
Old 05-15-2003, 04:32 PM
STOCK96civicDX
I take care of my member
STOCK96civicDX's Avatar
cool you got it fixed. if you ever want to leak test your gas tank, here's the cheap DIY way. get a valve stem and a spare gas cap that seals tight. drill the gas cap. push the valve stem in and silicone it in so it's airtight. then get a bicycle pump and pressurize the tank and listen for air hissing out. just some DIY
