Engine Start problem!
Old Dec 10, 2010 | 11:02 AM
nossimo's Avatar
nossimo
Default Engine Start problem!
Hey,
I have a 99 Civic Ex with 93K miles
I've been having problems starting the engine lately... here's the thing though.
1. when I start the engine every morning I go to work the engine starts just fine... however if I stop somewhere like to get gas and try to crank it again it wont start
2. when I turn the key it makes the normal sounds but it just doesnt catch
3. its been getting colder but I dont think that has anything to do with it because it started a little before then
4. engine cranks just fine with a jump
5. my oil filter hasnt been changed for the past 3 years and its 20k old so I'm going to start there
I thought maybe it was starter but I heard that if its starter a jump wouldnt help
Any suggestions?
Thanks
Old Dec 10, 2010 | 06:40 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I'm going to guess battery. Our Odyssey was having problems starting as it got colder. Even doing what you mentioned - lights and everything turned on but no cranking, but hooking it up with cables or a quick charger let it start up fine.
Took it to Sears to get diagnosed and they said the CCA (Cold cranking amps) were very low.
Autocross Help Page
Old Dec 11, 2010 | 07:23 AM
nossimo's Avatar
nossimo
The battery has lasted this long but its probably about time its changed out so I'll give that a shot.
Thanks for the suggestion!
Old Dec 13, 2010 | 07:58 PM
CivicSiRacer
Nowadays most batteries last about 4-5 years, 6 if you are lucky or in a stable climate (not extremes like the northeast). Our Odyssey had the original battery when we purchased the car in 2004. So it was about due anyway.
Autocross Help Page
Old Dec 16, 2010 | 01:42 PM
nossimo's Avatar
nossimo
Figured out the problem.... it was due to corrosion which was causing a bad connection... replaced the battery terminal to the cable and smeared this jelly Pep boys has to prevent corrosion
