zex install question
Old May 1, 2003 | 09:31 PM
spooncivicb16b's Avatar
spooncivicb16b
Default zex install question
my friend just got his zex kit and evrything is hooked up but we need to know which wire on the throttle position sensor to tap into. thanks
Old May 2, 2003 | 09:21 PM
spooncivicb16b
well i guess nobody knows but i found out so if any one needs to know its the red and black wire
Old Jun 26, 2003 | 11:45 AM
aznxguy12's Avatar
aznxguy12
RE: i got a del sol, majority it's the middle wire on the TPS.
Old Jun 26, 2003 | 11:46 AM
aznxguy12's Avatar
aznxguy12
oh yeah question, what engine do u have? and where to u plug in the 2 vaccum hoses? got any pics would help. thanks.
Old Jun 26, 2003 | 10:17 PM
spooncivicb16b
it was in my friends hatch he has a b16, i have a b16a2, sorry no pics
Old Jun 27, 2003 | 03:25 PM
BoOsTzex's Avatar
BoOsTzex
you have to test it with a volt meter...chances are its the middle one, likely black, but if in doubt jam a voltmeter prong in the back of the wire where it enters the clip; ignition on, engin off, 1 volt idle position, 4.2 - 5 volts WOT...
Old Jun 27, 2003 | 03:29 PM
BoOsTzex's Avatar
BoOsTzex
hose goes to the fuel pressure regulator, the other goes to the manifold...I can see it being confusing becaue the hose that zex gives you is way fatter than the hose you will be removing...thats why they included the hose clamps...you should only remove one factory hose from the engine.
