which headlight bulbs are best? *help*
hey im thinkin about buyin a set of those xenon plasma bulbs but dont know too much about them and dont have the money for a HID kit. anyways i was lookin at some on GBC:
http://www.groupbuycenter.com/buy.aspx?id=9887
http://www.groupbuycenter.com/buy.aspx?id=9872
http://www.groupbuycenter.com/buy.aspx?id=9725
which would be the best ones to go with and which type? i have a 94 civic ex coupe btw. also, i will loose my high beam if i change to one of those bulbs correct? im afraid of melting my harness so i figured i check out here and see if you guys knew anything about them and like what wattage to go with, etc. thanks :thumbup:
You will not lose your high beams. Silverstars are about $40 a set. The ones on GBC have poor lighting output and usually die after a couple of weeks. If you *have* to get one of the GBC ones, the Nokya ones have better quality than the others.
