State Ref visit, need some help fellas
Old Apr 29, 2003 | 11:02 AM
GReekbro's Avatar
GReekbro
Alexander the Great !
Default State Ref visit, need some help fellas
well the Visual part of the test went fine, welp minus the p28 ECU i was running (couldnt get my p72 h:
Comprehensive Visual Inspection: TAMPERED (ecu,and im good)
Functional Check: PASS
Emissions Test: GROSS POLLUTER :\
now i failed the emission test on high HC and CO numbers, take a look...
Idle Emission Results
HC #'s
Max- 100
GP-250
MEAS 443
CO #'s
MAX- 1.00
GP- 2.50
MEAS- 1.26 (idle-1036rpm & 1.78 MEAS 2500rpm-2588rpm)
[MEAS = amount measured] --- [GP = Gross polluter limits] --- [MAX = maximum allowable emissions]
now what could cause these high HC and CO emissions? can anyone analyze for me? i guess time for a diagnosis, any smog station will help me correct?
Thanks In advance ppl.
Old Apr 29, 2003 | 11:19 AM
dantastic's Avatar
dantastic
cx power!
wow.. they checked ur ecu?? damn.... now i need to get a p30 to get smogged.
anyway, make sure u have all ur "tune up" parts changed (sprark plugs, wires, rotor, wires) and fresh oil. also, how old is the cat ur using? just might be an old cat
Old Apr 29, 2003 | 01:54 PM
Outxider's Avatar
Outxider
X-Motoring
r u runnin a aftermarket header as well? if so that is a cause for the high co. but do check all the stuff dantastic mention.
Old Apr 29, 2003 | 02:23 PM
dantastic's Avatar
dantastic
cx power!
oh yea.... aftermarket headers (even carb exempt dc's) may not retain enough heat to warm the cat up to proper operating temps. make sure ur car is really warmed up (cooling fan comes on a few times)
Old Apr 30, 2003 | 09:36 AM
GReekbro's Avatar
GReekbro
stock 95 GS-R intake manifold...
anyhoos, im pretty sure its the ECU and the mugen prog im running on it, going back this tuesday with the p72, lets see if i can get that bar sticker this time
Old Apr 30, 2003 | 09:40 AM
preylude99's Avatar
preylude99
yea, sounds like the ECU, and also, was it fully warmed up when they tested it or was it sitting for a while? just curious, why did you have to take it to the ref shop? those places are beotches to go to in so cali, they check everything lol....
Old Apr 30, 2003 | 09:44 AM
GReekbro's Avatar
GReekbro
they are cool people, just trying to do their job i guess...
well the trip to escondido is a 30 minute drive from the middle of SD, i then had to wait around 15 minutes for them to start on it once i got there....
Old Apr 30, 2003 | 11:55 AM
dantastic's Avatar
dantastic
cx power!
oh yea... forgot to include taht. u need to run stock maps. the excess fuel will raise ur hc levels alot
Old Apr 30, 2003 | 07:44 PM
HappySnatch's Avatar
HappySnatch
OG
slip the man a $20
sup fawker :fawk:
Old Apr 30, 2003 | 08:08 PM
airon's Avatar
airon
AARONNOJIMA.COM
damn man mugen ecu=mad richness
good luck and do like everyone says
