B18 engine question
I know there is a 10hp difference in the engines between the B18B and the B18B1, but i was wondering if there is any difference in the way they are mounted. I have a 94 civic hatch and was gonna lay that bad mother in there. any help? thanks.
hmm... isn't there a different motor between the 90-91 integra and the 92+ integra? unless i'm mistaken i thought the B18B was in the 90-91 and the B18B1 was in the 92+. possibly wrong tho. so i guess there is no mounting difference then? thanks anyways.
92-94=B18a (and pre 92 maybe 90)cable tranny
95-01or02=B18B(hydro tranny)
both have the same HP and torq. mounts r the same
diff. is in the injectors wire harness will work on both in the eg. need a cpu from a 92-94
To elaborate on txhatch's post,
90-91 B18A1 = 130hp
92-93 B18A1 = 140hp
94-9? B18B1 = 142hp
9?-01 B18B1 = 140hp
I think the horsepwer drop occured in 96 with the introduction of the OBD-2 computer system, but I am not 100% sure. It is perhaps also better to say the B18A1 is from "non GS-R" 90-93 Integras, for the GS used it and was far from a base model. Also, from my understanding, the PR4 head castings are identical, but the cams and manifolds vary by year.
90-91 B18A1 = 130hp
92-93 B18A1 = 140hp
94-9? B18B1 = 142hp
9?-01 B18B1 = 140hp
So a B18A1 is in the 91 Teg? So the B18A1 has the cable tranny? hmm...alright then. The civic uses a hydro tranny if i'm not mistaken, so i don't think ima jump on it. I'll let you guys know if i take it or not. Thanks.
