thowing codes need help
Old Apr 19, 2003 | 07:54 AM
xbladr's Avatar
xbladr
Default thowing codes need help
Hey i have a 96 civic dx and im throwing codes as well as my speedometer bouncing off the wall.
codes
1 = oxygen content
20 = Electronic Load Detector
41 = 02 sensor heater
63 = Secondary o2 sensor circuit
67 = catalyst system
what do all these mean i need help email me xbladr@attbi.com any help is appreciated thanks so much i need asap
I have a question which fuse is fuse 15 i have no clue?
Old Apr 20, 2003 | 07:00 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
The best thing to do would be to start eliminating code by code. Sounds like you'd fix a lot of those by troubleshooting your o2.
Old Apr 20, 2003 | 08:32 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:werd:
I just ordered a sensor from www.sohfast.com for a really good price. It was used, but it's guaranteed. :thumbup:
Also, check out www.jdmfan.com for a better explanation of those codes. You may be able to get more detail on what to do there.
HIH
Old Apr 20, 2003 | 01:38 PM
honda guy's Avatar
honda guy
look under the dash at your fuse's if number 15 is blown thats your problem it usually throws 2 heater codes for the primary and secondary o2 sensors as well as an eld code. if its blown then there is a bracket under the intake manifol that supports it, attache to that bracket is a couple of connectors the harness most likely rubbed through tape the individual wires up and replace the fuse and you should be good. dont waste you time and $$$ with the o2 sensor untill you check that fuse
