Offset For 17" Rims
Old Apr 14, 2003 | 12:58 PM
97CivicSI's Avatar
97CivicSI
Default Offset For 17" Rims
I have a 1997 Civic SI and the Eibach Pro kit is on it's way. Im pretty sure that it is rated for a 1.5" drop. I was just wondering what offset i would need for 17" rims. Im looking at the Konig Tantrums which are 40mm offset , just want to know if those should be fine without having any rubbing problems etc.
Thanks
Old Apr 14, 2003 | 01:21 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Standard for our cars on 17s is 40 or 42mm so you will be fine.
Old Apr 14, 2003 | 01:43 PM
dantastic's Avatar
dantastic
cx power!
for a 17x7, 45 would be best. with anything from a 40-45, the tire will still rubb the inner fender when you turn the wheel all teh way to one side
Old Apr 14, 2003 | 01:59 PM
riding low's Avatar
riding low
I have 17"x7 konig traffics on my 00 civic with eibach sportline drop, not sure what the offset is.. but everything works fine.
Old Apr 14, 2003 | 04:18 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
To play it safe you need a 17x7" rim with 42-44mm offset and 205/40x17" tires.
Autocross Help Page
Old Apr 14, 2003 | 06:23 PM
Brad's Avatar
Brad
wooo nascar!
96 ex---eibach pro kit---17x7 43 offset 5zigen rims---no problems.
Old Apr 14, 2003 | 06:47 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
42 is probably the standard for our cars in that size.
Old Apr 14, 2003 | 07:11 PM
97CivicSI's Avatar
97CivicSI
All i can find for rims that i like is 40mm, like i said before i like the Tantrums and i also like the Motegi MR7's but they only come in 40 as well. Does anyone know of a rim that is similar in looks that will come in 42?
Thanks for replys so far guys.
Old Apr 14, 2003 | 07:14 PM
asiandoood's Avatar
asiandoood
40 should be fine.
Im running a 38 on my 15's on a 2.5 inch drop. I wish they came in 40...but Im doing fine so far.
Old Apr 14, 2003 | 07:56 PM
cobbcustomz's Avatar
cobbcustomz
99 civic ex with 17x7 konig tantrums with a 40mm offset. I am dropped 1.75-2 inches and had rubbing issues originally. I rolled my fenders and the rubbing issues are non existent now. perfect camber in front Slight negative camber in the rear
