ITR sway bar
anybody put this on a 99-00 Si? I can a great deal on one for under$100. itr sway bar, itr endlinks, all d brackets & prothane bushing kit included :thumbup:
post pics if have 'em.
Originally posted by dnt94civic
if you do this, you don't need the itr endlinks. you need the Si endlinks. Also, you will need the si mounting brackets to connect to the subframe
Have pics?
Originally posted by 4-banging
i would need the ITR mounting brackets because the ITR bar is larger...wouldn't I?
Have pics?
Have pics?
if that's the case, you will only need to get the ITR rear sway bar, and the D-brackets for the ITR.
I would also recommend that you get a reinforcement kit for the subframe. like the beaks kit.
If you Don't have an 99-00 Si, you will need Si endlinks, and the Si mounting brackets. as well.
Okay, If you have a 99-00 Si, you already have a rear sway bar.
Get the BSQ or Beaks kit to reinforce that subframe. Tearing it out will make your life miserable. Good buy on the bar :thumbup:
