turbo b16A2 engine rebuild
Old Apr 3, 2003 | 12:50 PM
spoyled27's Avatar
spoyled27
Default turbo b16A2 engine rebuild
I have a 1999 usdm civic SI. I have 60 k miles on it. I was running 8lbs of boost on factory internals. Its a DRAG GEN III kit. I blew my piston rings in two cylinders. I need to rebuild and was thinking of going with JE forged pistons 9:1 compression and eagle rods. My goal is 12-15 lbs of boost. I would also get a blockguard. Do I need to re sleeve the block or anything else like that? Thanks for your help
Old Apr 3, 2003 | 12:52 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Was it tuned at all?
Old Apr 3, 2003 | 01:04 PM
spoyled27's Avatar
spoyled27
yes, I have an apex i s-afc. air/fuel was around 13.1 throughout the powerband.
Old Apr 3, 2003 | 03:24 PM
Hondaman's Avatar
Hondaman
Black Pearl
I didn't know that those blocks were sleeved. Is this an OEM thing, or is it and aftermarket thing?
Old Apr 3, 2003 | 03:26 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
stock b16a2 blocks are not sleeved....and what kind of fuel management were you on when you blew up at 8 psi. That seems kind of low boost to detonate if you are well tuned.
Old Apr 3, 2003 | 03:35 PM
ManTiS's Avatar
ManTiS
NinJA
You don't have to sleeve it unless you want to make lots, I mean lots, of power.
A local guy makes ~390whp on C1 stock sleeves. Runs high 10's in a stripped hatchback.
Old Apr 4, 2003 | 03:53 AM
spoyled27's Avatar
spoyled27
stock b16 do have sleeves, it's an open block. And for fuel management I had a vortech FMU and an extra fuel pump.
Old Apr 4, 2003 | 03:54 AM
spoyled27's Avatar
spoyled27
my compression was 10.3.
Old Apr 4, 2003 | 05:23 AM
4-banging's Avatar
4-banging
so then, NO, you weren't tuned... :nono:
Old Apr 4, 2003 | 05:26 AM
4-banging's Avatar
4-banging
ps...you need this instead of what you have.
