worst directions EVAR!! HELP NEEDED
Old Mar 31, 2003 | 12:06 PM
darkcyde's Avatar
darkcyde
Default worst directions EVAR!! HELP NEEDED
Well I finally got my fog lights today. Too bad they came with teh worst directions evar! I can't even read the ****in writing on the install directions. anybody installed them on a 92-95 2door before? Also, I want to wire them up so I can have just the fogs on and no other lights on (like no corner lights, headlights, or back lights....just teh fogs) anyone know how to wire them up??? plz help out ASAP, thanks!!
Old Mar 31, 2003 | 02:21 PM
Hondaman's Avatar
Hondaman
Black Pearl
Are they OEM? If not, what brand name are they?
Old Mar 31, 2003 | 02:34 PM
EX R8ED's Avatar
EX R8ED
is whipped
http://www.hondaautomotiveparts.com/.../16603_01.html
I'm assuming they're OEM style.
Old Mar 31, 2003 | 03:42 PM
randomtask77's Avatar
randomtask77
Wanderer
Default Re: worst directions EVAR!! HELP NEEDED
Yeah, the depo lights (I'm assuming that you have the OEM style fogs) directions are pretty horrible. The Honda Automotive Parts link should help in that. The only thing that didn't come with (at least mine didn't) is the template to cut out the bumper.
Crucial Si also installed a set on his car. He might be able to help you out further...
Old Mar 31, 2003 | 04:35 PM
dantastic's Avatar
dantastic
cx power!
the real oem lights are waaaay harder to install than the depos.
the instructions i got were actually just the oem honda instructs, shrunk down so they were impossible to read.
-- the fogs mount to the bumper 3 screws and to the body with one bolt.
-- the one red wire with a ring terminal goes to the battery, the black goes to ground.
-- i screwed the relay into a factory bolt location near the air filter. then u run the 2 plugs for the fogs to the front, using the zip ties with anchors to keep them tied down.
-- theres one wire that u run through the driver's side harness grommet.
-- u may need to remove the panel under the steering wheel to get the green plug to the fog switch.
-- u also need to plug the brown plug into the fuse box. u can plug it into any of the available spots on the fuse box. mine is plugged into the parking light one, so they can be turned on as long as my parking lights are on
Old Mar 31, 2003 | 06:15 PM
darkcyde's Avatar
darkcyde
ok so i wired them up and they work and shit which is good but.... when i hit the switch to turn them on, they come on, but when i hit the switch to turn them off, they dont go off. whats the deal???
Old Mar 31, 2003 | 06:32 PM
crucial Si's Avatar
crucial Si
Banned
do a search either on my name or oem fog lights...or something along those lines..i explained it plenty of times.
