Transmission fluid
Old Mar 23, 2010 | 05:40 AM
themonsteraria's Avatar
themonsteraria
Boats n hoes
Default Transmission fluid
With the next oil change, in about 500 miles, I'm going to change my transmission fluid. Last time I did it, about 15,000 miles ago, I used Syncromesh fluid. It's worked great, but I can tell that after only 15,000 miles the shifts are getting a little rougher. So I'm thinking about changing fluids. Does anyone have any ideas suggestions? It's my DD, but I do run it kind of hard. I was thinking about going back to Honda MTF, but last time I used it I was disappointed with it; the shifts were noticeably rougher then with Syncromesh.
Thanks for any suggestions.
Old Apr 5, 2010 | 08:22 PM
Redline96LX's Avatar
Redline96LX
new OEM fluid!
Everyone likes Synchromesh at the beginning, but no one gives LONG TERM reviews. There is a reason. Its shit. It was designed for a different viscosity for the Corvette which doesn't have a Honda-quality gearbox.
I ran it in my y7 tranny. Made the shifts feel smoother at first. But it ended up affecting the tranny. It got worse and worse and what happened was the fluid affected the internal bearings. It caused the bearings to wear and create friction. When i swapped to the y8 tranny, i spun it by hand and the y7 was NOTICABLY harder to turn, almost unable to turn by hand while off the car. So take it from me. You can't outengineer Honda with a cheaper fluid. Stick with OEM fluid (or actually the book reccomends a motor oil). Clean fluid can get in there and make your shifts a bit better, but worn synchros can't be masked by that fluid, it'll mess up the bearings.
Old Apr 6, 2010 | 05:13 AM
Line7's Avatar
Line7
Platinum Member
Try 10w-40, I couldnt get HMTF when I was last filling my tranny so I just got regular oil, and it worked good for me.
Old Apr 6, 2010 | 08:38 AM
IanB's Avatar
IanB
MB4
OEM Honda fluid.
Old Apr 6, 2010 | 10:14 AM
themonsteraria
Boats n hoes
OK. So everyone thinks I should just go ahead and use OEM Honda MTF? Well, I might have to give it a try.
Thanks
