shifter problem
Old Mar 24, 2003 | 07:31 PM
huviduc's Avatar
huviduc
Default shifter problem
i was just wondering if anyone can give me alittle advice. i have a 95 civic DX with a DC sports short shifter and energy suspension bushings. Before i bought the bushings i posted and said that my shifter seems to stick alittle before going into gear(mainly second) and everyone said to go buy some shifter bushings. well i went and bought some and they didnt seem to help much at all, im not even sure if it changed anything. i was just wondering if there could be something else wrong. could i have installed it wrong? i cant think of anything else i can do.
also, alittle off that subject, but will the same shifter work when i get my h22 or GSR swap?
Old Mar 24, 2003 | 08:30 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
Default Re: shifter problem
the answer to this question is no,...sorry i couldnt answer your other question
Old Mar 24, 2003 | 09:01 PM
Kai's Avatar
Kai
Rotorphile.
H22 transaxles use a cable shifter. Completely different design.
Old Mar 24, 2003 | 09:04 PM
Outxider's Avatar
Outxider
X-Motoring
it could be ur tranny is goin out?
Old Mar 25, 2003 | 07:45 PM
huviduc's Avatar
huviduc
i dont think it could be my tranny because it didnt start to catch until i put in my short shifter. and my tranny seems to be working alright
Old Mar 25, 2003 | 09:15 PM
Outxider's Avatar
Outxider
X-Motoring
what exactly do u mean stickin? i was wonderin if u have tighten the shifter to the linkage a little too tight?
Old Mar 25, 2003 | 09:20 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
could it be catching on the exhaust piping:dunno:
Old Mar 25, 2003 | 10:31 PM
dantastic's Avatar
dantastic
cx power!
maybe the shifter is screwed in too tight so its binding
Old Mar 26, 2003 | 05:22 AM
huviduc's Avatar
huviduc
when i have the car off i can shift back and forth between all gears and it slides in and out as smooth as possible. when i have the car on, and i try to shift it is still really smooth coming out and going to the gear. but when i try and put it in gear it wont go in for a sec, it sticks there and than goes in. everything seems to be pretty loose and smooth except for going into gear.
Old Mar 26, 2003 | 08:21 AM
dubss's Avatar
dubss
my short shifter doesn't stick but it had gotten a bit harder to shift...also it squeaks going from 1st onto 2nd and 3rd into 4th i greased it up like crazy so i don't know why its doing it. and its not cause of the heat shield contact..i checked.
