trailing arm bushings?
Old Mar 19, 2003 | 12:12 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Default trailing arm bushings?
hey everybody. I posted this question on the integra board, but nobody seemed to know, so I thought I'd ask here.
Anyway, I ordered the Energy Suspension trailing arm bushing kit for a 94+ integra (#16.7106) since I have integra trailing arms from a brake swap. But Driver FX sent me the kit for a 90-93 integra instead (#16.7107). So I was wondering if anyone knows if the trailing arm bushings are the same for 90-93 tegs and 94+ tegs. I really don't want to have to return these.
thanks!
Old Mar 19, 2003 | 12:46 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Tough call.. Call up honda and see what the part numbers are. Or call up ES and see if they have different ones for the 2 different generations.
Old Mar 19, 2003 | 12:54 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
throw up a picture of the bushings.
i bet it's the same.
btw. my trailing arm bushings are done! h:
good luck biatch!
Project EVA - The Track Package
Project EVA
Old Mar 19, 2003 | 01:32 PM
white_n_slow
it's my D in a B
bumnah... did you end up using the ES ones? How did you get them in? Details Please!
Bakeoff...ES has 2 different part #s for the older and newer ones (the #s in the first post). I'll try honda tomorrow or the day after. Boulder/denver is completely shut down from a blizzard.
They look roughly the right size, but its impossible to tell for sure because the lip of the ES bushing is a little oversized. I also don't want to take them out of the package until I know if its the right one, so I can return it if I need to.
Old Mar 19, 2003 | 02:22 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
truthfully one of the easiest bushings to put in. yes, I did use the ES kit. I decided I would toy with them to see if I could do the install, and if I had problems I'd just overnight the Prothane inserts.
How i did 'em: i took out my handy dandy drill. I started drilling the rubber piece that is molded to the center roud pin. I drill all that rubber and got the middle pint and a good chunk of the rubber loose. Now all I had left was the rubber around the outer sleeve. On my bushings I had the outer sleeve and another piece of metal on each side. I then again pulled out the drill, and drilled the rubber and removed the metal plates on each side. Now all i had left was the rubber attached to the outer metal sleeve. I went to my local performance shop (Home Depot) for help. I was told the only way to do it was to cut the rubber away. I tried this for about 20 mins, and noticed I was going no where fast. So I decided to focus on the middle pins rubber first. I took the metal piece to my friend house who hand a bench grinder with wire wheel. We turned it on, and just put the pin up to it and see what happens. It was removing the rubber pretty quickly. But left a horrible mess and scent. But the results were awesome. So i had him grind up all the metal on the pins. Took him about 20 mins a pin to do, but they were perfect, and very bling bling.
I used the same method. I got a wire brush attachment for my drill, and just started grinding. It's only hard when you first start.
Over all pretty cake.
I just have the bushings for my ITR rear lca's left, and those look like they'd be the biggest bitch to do. so blah.
Project EVA
Old Mar 19, 2003 | 02:39 PM
agent87's Avatar
agent87
Need zzzzz's
Bumnah, awesome detailed explanation. I guess a wire wheel might someday see its way into my future for the "bling bling" factor. Thanks.
Old Mar 19, 2003 | 05:57 PM
white_n_slow
it's my D in a B
thanks bumnah, but I've already figured out the removal. (after I attacked it with the dremmel the whole neighborhood smelled like burnouts) I used a chisel and a sharpened screwdriver [homemade mini-chisel] to remove most of the rubber and got the rest with the dremel
I was wondering more about the install. How did you get the new ones in?
Old Mar 19, 2003 | 08:34 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Axle grease. Tons of it. I pushed the side with the writing on it in. It was easier if i put it on that side. Just grease up the sleeve and the bushings real good. and then just put your body weight into it. It popped in within 10 seconds.
I also just greased up the inner sleeve real good and pushed that in also. It said to take measurement of the inner sleeve according to the directions. I just remember to keep the oval hole on the outside, and I measured the end of the middle sleeve to the trailing arm and it was like 62 centimeters or something. And slide it in till it look right and took a measurement and I was pretty close. I'm just gonna have the guy who's doing the alignment fix it if it's off. Those directions weren't too clear so I didn't really sweat it too hard.
I just hope it bolts back up no problem.
I've got pix of the bushings and stuff here.
Project EVA
Old Mar 19, 2003 | 11:32 PM
white_n_slow
it's my D in a B
Your link isn't working for me. So I can just force that thing in by pressing on it with my fat ass? So will I need more grease than the kit provides? Should I go out and buy some more?
Thanks.
Old Mar 20, 2003 | 04:59 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
i never use the grease they give me. i dip everything into axle grease. No problems at all... i bought like a tub of axle grease for $4 from trash auto. Using it still.
BTW. My trailing arm kit for the Civic trailing arms was 16.7106G,
fixed the link also.
Project EVA
