Turbo Q's
Old Mar 6, 2003 | 12:29 PM
00-00-00's Avatar
00-00-00
E M I N E M
Default Turbo Q's
can anyone give me some info for a turbo on a 00' SI?
like cost... hp gain... brand... and what kind of other mods are needed?
thanks
Old Mar 6, 2003 | 01:48 PM
antarius's Avatar
antarius
Large Member
If you want to do it safely, a complete fuel system and a standalone or otherwise engine management system (such as Hondata).
Drag Kit, Hondata, RC Engineering Injectors, New Clutch, New Flywheel, New Fuel Pump, New Oil Pan, All the lines and crap.
You're spending ~$5500 for a good setup, to be as reliable as you can without doing engine work and you could run 7-9psi on it.
Im not sure of the gains on a Civic though, Id imagine ~100hp.
Old Mar 6, 2003 | 02:10 PM
ManTiS's Avatar
ManTiS
NinJA
Since you're a novice, GReddy kit
Old Mar 6, 2003 | 02:15 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
What he said but rev hard kit, and a flywheel would be a waste. Also your stock oil pan will work fine. My setup was rev hard stage 2, rc 550cc, hondata s200, 3" custom exhaust with apexi n1, act clutch. I was reliable up to 12 psi.
Old Mar 6, 2003 | 03:52 PM
DSC's Avatar
DSC
Long way from home
#1 Good fuel management.
Old Mar 7, 2003 | 04:56 AM
4-banging's Avatar
4-banging
Default Re: Turbo Q's
thanks
Cost--->will depend if you go custom or buy the kit. I've seen custom kits for as low as $2300.0 and that was the good stuff....garret t3/t04 turbo, tial wastegate, greddy BOV, Maxrev IC, MaxRev mani and downpipe with all the misc. stuff
HP--->tuning is the key but roughly 80+ at the wheels
Mods--->standalone (AEM EMS or Apexi Power FC), bigger injectors, ignition, tune..tune..tune
**off the top of my head I prolly missed some stuff**
Old Mar 7, 2003 | 06:55 AM
oscarmayer's Avatar
oscarmayer
I agree with the Greddy kit or Revhard. Dont get sucked into that you ahve to run a standalone yet. if you run teh stock set boost of a greddy or other named brand kit, then you will be fine. they send everything needed for your car to operate correctly. When you finally want more, then you can persu the avenue of standalones or piggy backs. but till then, just use the stock kit. You'll be fine and your car will not have an issue at all. Just rememebr do NOT turn the boost up at all. leave it set to what they set it to.....
Good luck.
Old Mar 7, 2003 | 07:36 AM
4-banging's Avatar
4-banging
Good luck.
yea, good luck doing that h:
Old Mar 7, 2003 | 09:45 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
:werid:
i dont think id go all the way, big time boost and power if you never had it before.
