Last question about swap(b18c)
Old Mar 5, 2003 | 02:16 PM
Slacker's Avatar
Slacker
Default Last question about swap(b18c)
OK, here's the last question before I do the swap Engines already purchased and I am putting it into a 99 civic ex. What wiring changes need to be made if the GSR motor I am buying is from a 99-00 teg? If any? Thanks! I know I don't need a harness anymore, but will I have to re-wire anything. Thanks for all your help guys!!!
Old Mar 5, 2003 | 04:48 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You need to bury yourself in www.c-speedracing.com www.jdmfan.com and www.hybridgarage.com
I don't know for the 99 cause I did a 95, but you'll prolly need the evap sensor and maybe knock (not sure about the D16Y8 and knock - I think it does, but don't know about the ECU harness positioning)
You will also need a throttle cable and throttle cable bracket from a GSR.
