View Poll Results: which one
b16
2
10.00%
b18
12
60.00%
h22
6
30.00%
b20
0%
Voters: 20. You may not vote on this poll
Swap question
Originally posted by madlow
personally, H22A
200HP & 165TRQ
I have a b18b1 now in my civic and it's ok. I had to get a n2o kit to give me some more power.
personally, H22A
200HP & 165TRQ
well two of my roomates have b18b's in there hatches currently and they stay pretty competitive for our little town in nebraska i persoanally wouldnt mind one myself.
me personally i am going with the b16a2 in my hatch and so is my buddy but the motor wont be here till next week so i really cant comment if i made the right choice yet
but either way i just wanted something different cause there are like 4 or 5 (i think) b18b civics in town and no b16's so that is the main reason i made my choice its all about what you want and to me what others dont have
Originally posted by bigunitsnake
whats the problems in turboing a gsr motor
The GSR has high compression hence high RPM's for top-end power as stated above.
My vote is B16a1 it's a little more work to get installed in a 5th gen, but it's cheaper than all of the other motors. the reason it's cheaper is cuz it has a cable tranny, this really isn't a factor though, because hasport sells an adapter and it works perfect (isn't even hard to install) you'll be competitive with gsr's (hatches with gsr swaps will have a slight edge on you...but the win will more often go to the better driver than the larger displacement engine) also the tranny on the b16a1 is SICK low gearing. i don't know the numbers, but i do know that at 75 mph in 5th gear your running at like 4200 rpm.... this may sound kinda crazy, but if you think about it, it makes an ideal tranny if you're running NA and you want to get off the line quickly.
just my .02 but i will also caution you that it's a little hard to find parts for them. they are MORE OR LESS a del sol dohc vtec engine, but some things are different (like the throw out bearing for the clutch) but if you do a little reasearch you can find out what parts to order for it.
