1997-01 Integra owners check within
I realize this isn't the Integra forum, but am hoping someone who has done a swap may have both Honda Civic and Integra manuals available to answer this question.
In search of a 1997-01 Integra owner with a Helms manual and/or something lower or equal to a Helms, that would provide assistance. Any manual or answer from anyone that knows the 16 pin layout for the blue harness of the gauge cluster. There are two blue plugs consisting of a 13 and 16 pin found behind gauge cluster of the Integra dash, along with them is also a yellow plug. In search of the individual functions for the 16 pin from left to right. Example: red/green fuel, yellow/black ground. I would greatly appreciate any answers, sites, or other members you could direct me to. I appreciate your time and efforts, thanks.
JDM Fan Boy
Eater of Rice
Cluster swap?|
Here's mine
As to what you need for wiring:
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
Here's mine
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
5. wht/blu charge
8. blu tach signal
10. blk/yel power
11. red/blk power
12. red power
6. blk ground
8. yel hot
9. grn trunk switch
Originally posted by incublinkus
i think www.jdmfan.com has a diagram of what you need. You swapping gauges or something?
Appreciate the help thus far, anyone with a manual on this so that I may get the colors of the wires and functions?
Anyone also with a 92-95 Helms? I won't have mine at least until next Monday
Originally posted by Paul
[B]Cluster swap?|
Here's mine
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
[B]Cluster swap?|
Here's mine
1. blu tach signal
8. blk ground
10. yel hot
6. blk/yel power
7. red/blk power
8. red power
Those larger ones there are all different on the 98-01 Integra.. I was in a slight rush, I am getting set to get another customer call...but it is those final slots I am talking about.
EDIT: off the call fixed what I wrote.
Are you going from OBD1 to OBD2? I think there are slight differences if Im not mistaken that you need to modify them to work.
Yes, it would be from OBD1 to obd2, but I wouldn't think it would make a difference regarding the cluster because the 1995 Cluster is obd2 as well, at least late 1995. Unless early 1995 then it is more then likely obd2, so I don't think it matters too much, but I could be wrong.
Any help is still appreciated.
Anyone with the 1992-95 Civic Helms manual on hand?
I remember hearing from Katman (FFsquad) that when he tried to wire up a 99-00 Si cluster into Dylan's car (Goldie) which was OBD2 was a pain in the ass. He did not recommend it.
I thought all 92-95 were OBD1. Not until 96+ were they OBD2. I could be wrong.
Anyone with a 1992-95 Civic helms :leftarrow: redundant I know.
No you are right on that, but that is for the Civic side, the 1995 late model integra should be obd2, I am almost 99% positive that the 96 Integra is obd2.
oh my bad...I misread h:
