B18C swap
Old Jun 22, 2002 | 09:34 PM
SSCivic's Avatar
SSCivic
Swolen Member
Default B18C swap
are B18C engines a direct sap into a 2000 civic coupe? as in no problem, easy fit, mad easy?
Old Jun 22, 2002 | 09:36 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
it should be a direct bolt in.
somebody confirm me on this.
Old Jun 23, 2002 | 09:04 AM
NOPD's Avatar
NOPD
Come in My Hole
no, u need a 99 si and up driver side mount and some other mount i forgot.
Old Jun 23, 2002 | 09:32 AM
pinoydon2003's Avatar
pinoydon2003
hey, it seems like there's a lot of yellow civics on these boards, i feel right at home
Old Jun 23, 2002 | 10:33 AM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Hmm, I thought stock Civic mounts would work, but I guess I was wrong!
wned:
Old Jun 23, 2002 | 11:30 AM
95LSTypeII's Avatar
95LSTypeII
They'll work, at least I think...
You only need new shift linkage, axels, and ecu...
Old Jun 23, 2002 | 12:03 PM
skubb's Avatar
skubb
not that TLC sh!t either
think about it the d series is a different engine. like NOPD said you need the mounts from an si to put in a b-series engine. after that it's pretty straight forward.
Old Jun 23, 2002 | 09:29 PM
SSCivic's Avatar
SSCivic
Swolen Member
Hm.... I have a guy who is selling a complete B18C1 Swap... I'm assuming that's engine harnesses too.. but I'll have to ask him about that one. Thanks for the help guys I'll look into Si Harnesses and see what they're running nowadays. Great help! Thanks!
Old Jun 24, 2002 | 08:29 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
You can use your stock wiring harness and modify it. You'll have to get a 99+ gs-r ecm or do some ecm pigtail swapping. And if you're going to do that, might as well go obdI. As for the mounts, you'll need the 99+ Si driver's upper bracket (bolt's to block) and 99+ Si rear tranny bracket. After that, you use the B brackets and D mounts. Hope this helps.
Old Jun 24, 2002 | 11:44 AM
SSCivic's Avatar
SSCivic
Swolen Member
thanks for all your help
