Question about vtec???
Old Oct 13, 2009 | 08:52 PM
d_razo's Avatar
d_razo
Default Question about vtec???
ok here's what's going on. I was hanging out with some friends and they said my vtec wasn't engaging. is this possible if so why? I have a 95 honda civic ex coupe.
Old Oct 13, 2009 | 08:58 PM
Shameinator's Avatar
Shameinator
it is possible but what made them say that? Because that is rather random to just be like oh your V-tec isn't working. It could be alot of things but my bet wuld be a bad v-tec solenoid. Who knows though without a list of symptoms. What motor do you have in your car?
Old Oct 15, 2009 | 08:06 PM
d_razo's Avatar
d_razo
I have a z6 with about 160k on it. how would I check the soleniod
I have a z6 with I little over 160k on the odometer. how would I check if its the soleniod?
Old Oct 15, 2009 | 09:19 PM
Shameinator
I dont know how you would go about it specifically but my guess would be take it somewhere and get it diagnosed. I believe it throws a cel light if its bad but im not sure.
Again why do you think its not working?
Old Oct 15, 2009 | 09:27 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
also check your oil. if your low on oil it wont kick over either.
Old Oct 16, 2009 | 06:52 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
First thing i'd check is definetly oil - low oil pressure can cause it to cut out of vtec, or not engage at all. Also (I'm not sure on the Z6 motor) but on most others, if it is not up to a certain termperature yet, vtec won't kick in. So if you just left your driveway and planted it - probably not gonna engage.
Old Oct 17, 2009 | 12:50 AM
pslsnakes's Avatar
pslsnakes
F#%K JDM, USDM FTW
Oil pressure
Coolant temp
Speed sensor
Those three things need to be opperating/working order for vtec to work. I will also add that it's not very easy to hear vtec in a single cam like a B-series or H-series motor.
Check those things, if every thing seems fine, the vtec solenoid screen may be clogged, check that. Put a test light in-line to your vtec solenoid and see if it lights up when vtec is supposed the engauge.
Old Oct 17, 2009 | 08:35 AM
d_razo's Avatar
d_razo
I will check those things today when I get off work. thanks
Old Oct 18, 2009 | 02:12 PM
d_razo's Avatar
d_razo
well I check the oil and it was low so I added took it for spin around the block and bam vtec kicked. thanks guys I appreciate it
Old Oct 19, 2009 | 11:40 PM
uncleoms2001's Avatar
uncleoms2001
AAAAAAAAAAAAAGAGAGAGAGAGGAGAGA:jawdrop:
