check engine light.
Old Feb 20, 2003 | 08:46 AM
mobius's Avatar
mobius
Default check engine light.
I'm yet to replace my engine, so i still have my 00 dx engine. My engine light went on this morning. I'm not leaking any fluid and all my belts seem to be in tact. I tightened my fuel cap after I pulled over to check all this. I called the dealer and he said that i would have to start and drive my car 8 miles 3 times to reset the functions if it were the fuel cap not being tight enough. What else could it be and can you reset it any other way?
Old Feb 20, 2003 | 09:07 AM
xBaByGrLx's Avatar
xBaByGrLx
go to a local autozone, they'll check the codes and reset it for free.
Old Feb 20, 2003 | 09:14 AM
mobius's Avatar
mobius
thx. if it's not that....what else could it be?
Old Feb 20, 2003 | 09:21 AM
xBaByGrLx's Avatar
xBaByGrLx
it could be a variety of things.. thats why u gotta check the code to see what's wrong.
Old Feb 20, 2003 | 09:23 AM
mobius's Avatar
mobius
right. i just called them, they said they can't reset the codes unless they install the parts first....by law. they will do the gas cap thing though. thank you xBaByGrLx
Old Feb 20, 2003 | 09:27 AM
xBaByGrLx's Avatar
xBaByGrLx
at least have them check it to see what's wrong so u can correct the problem. then i think u can reset the ecu yourself by either disconnecting the negative battery lead, pulling the backup fuse in the underhoood fuse box, or disconnecting the ecu at the plugs
Old Feb 20, 2003 | 09:40 AM
mobius's Avatar
mobius
sweeeet!
Old Feb 20, 2003 | 12:04 PM
str8edgexx's Avatar
str8edgexx
yeah...tighten the gas cap and reset the ECU as they said (just take off the negative terminal, wait a minute or so, and hook it back up)....that should hopefully solve your problem
Old Feb 20, 2003 | 12:46 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
Check the codes yourself! All you need is a paper clip!
Old Feb 20, 2003 | 02:48 PM
96extec's Avatar
96extec
Paper clip does not work for a 00 civic 92-95 might work. 96-00 is running obd2 computer.
