front interior light
Originally posted by jordan88
so there are holes for me to mount the light already right? all i need to do is cut that thing that is covering it? so how do i run the wires?
thx
thx
The wires will not be seen because of the headliner, but it is only going to be one wire because the light will ground itself once you place the screw in. I ran the wire from the maplight to the driver side and spliced into a existing power source, I believe it was the dome light power source, if not you can always run it off the another power source cause once you remove the pillar, which you will need to anyway to get the headliner down, you will see all the wiring for the antenna and domelight there on the left pillar.
EDIT: I had a EX so it was a bit easier when it came to the headliner cause with only 1/4 of it removed I could easily work through the area where the sunroof begins.
Just found this:
http://www.honda-tech.com/zerothread?id=419845
