Mugen Twin-loop/CTR cam Questions
Old Feb 8, 2003 | 03:49 PM
PearlBlueB16's Avatar
PearlBlueB16
Default Mugen Twin-loop/CTR cam Questions
Would stock piping, performance cat, and a twin-loop muffler on a 2000 civic si be adequate for proper exhaust flow? Also, Is it true that you can use a CTR intake cam, and replace your stock exhaust cam with the OEM intake cam?
Old Feb 8, 2003 | 06:54 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
Stock exhausts are usually very retrictive. You might want to get a new cat and some bigger piping done to go with that muffler.
Intake and exhaust cams are different I would think.
Old Feb 8, 2003 | 07:33 PM
DSC's Avatar
DSC
Long way from home
Get a 2.25 piping.
If your gonna get the CTR intake cam might as well get the exhaust cam as well.
Old Feb 10, 2003 | 09:10 AM
4-banging's Avatar
4-banging
betweeen 2-1/4" or 2-1/2" piping is good for NA & 3" for turbo.
as far cams for a NA, CTR and ITR combo work good.
Old Feb 10, 2003 | 09:23 AM
94civicEX's Avatar
94civicEX
I got worms.
I'd get piping as well, isn't gonna' run you too much more than what you are spending already. Also, I don't think that you can use an intake cam for an intake cam.....they are different, no :eh:?
99 Integra GSR
06 TSX
duck squad member #00003
Old Feb 10, 2003 | 03:54 PM
SiClone's Avatar
SiClone
X-Moder8er
Default Re: Mugen Twin-loop/CTR cam Questions
If you want good flow, then get better piping than stock. A good header like a JDM 4-1 or DC jdm 4-1 will be nice, too.
As for the cam question, you can replace just the intake cam and leave the exhaust one. Do not use the intake cam on the exhaust side. It doesn't work like that. But since you have to do quite a bit of work to install the CTR intake cam, might as well install the exhaust cam, too.
