Engine is in and I'm close to cranking but.....
Old Feb 4, 2003 | 10:25 PM
ImportRac3r's Avatar
ImportRac3r
Elite Member
Default Engine is in and I'm close to cranking but.....
We'll tonight I finally got the engine in and plugged in. I bleed the clutch and it was finally that BIG moment. I turned the key and fuel starting fountaining out of the top of the fuel filter. I had forgotten the bolt that goes into the top. Then I go to crank it again and again nothing happens. The starter is turning the crank but the engine isn't sparking. I pushed on top of the fuel rail and the injectors and theres a leak. I know it isn't the cables or nething electric. Whats this cause of the injectors doing this. Could it be a bad fuel rail or injectors thats keeping me from starting? The HANS wasn't much of a help. Thanks and I'll have pics as soon as its cranked. :thumbup:
Old Feb 4, 2003 | 10:28 PM
Outxider's Avatar
Outxider
X-Motoring
umm did u put the injector seals bakk in properly? cuz it might not of sat properly hence the leak. recheck those.
late
Old Feb 4, 2003 | 10:30 PM
ImportRac3r
Elite Member
late
I never took the injectors out nor the fuel rail. Could the injectors just have a bad seal. If so wouldn't the engine still crank even though theres a small leak in them? I'm just trying to trobleshoot.
Old Feb 4, 2003 | 10:52 PM
Outxider's Avatar
Outxider
X-Motoring
hmm, try to check em anyways. could be a bad injector or seal.
late
Old Feb 4, 2003 | 11:40 PM
ImportRac3r
Elite Member
Could it be something else other then that too maybe.....my wires, distrubor, etc...?
Old Feb 5, 2003 | 02:34 AM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
there is or isn't spark?
Old Feb 5, 2003 | 02:35 AM
ImportRac3r
Elite Member
no spark
Old Feb 5, 2003 | 02:16 PM
ImportRac3r
Elite Member
^^^bumpy de bump^^^
Old Feb 6, 2003 | 02:20 AM
SpeedRacerEX-R
Check your coil? Are your plugs fouled?
Old Feb 6, 2003 | 12:47 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
if there's no spark, that has nothing to do with the fuel rail. You can check the coil and ignitor with a multi meter.
