E85
Old Jun 25, 2009 | 09:43 AM
Smurf's Avatar
Smurf
Dancing Banana Driver
Default E85
Any one ever switched thier car to run on e85?
I would like to do this but i am not rela sure where to start
I found a change over kit but ... it looks fishy .. http://www.change2e85.com/servlet/Page?template=honda
Old Jun 25, 2009 | 02:08 PM
fathergoat's Avatar
fathergoat
:3
I run it because it's high octane (turbo setup). You will get worse milage so you will not save any money switching over.
Old Jul 7, 2009 | 01:07 PM
Civic2Scooby's Avatar
Civic2Scooby
I'm with lance, unless you are looking for effectively cheap "race" gas for a high octane setup, the pros do not outweigh the cons.
Old Jul 27, 2009 | 03:42 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I think it would be cool if said E85 convert stuck his face out for everyone to slap him as they walked by, and maybe occasionally he could slap himself..... drive that car by low hanging branches so as to be slapped by prickly twigs... that sort of thing.
No offense intended seriously, I just really HATE E85. I don't think it will work, not by any stretch of the imagination, not for the U.S. The government has wasted time on it because of political favor doing or whatever it's called and there are so many more viable options that should've been developed decades ago.
Old Jul 27, 2009 | 05:15 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
It's impractical and pointless for a DD, but countless people have proven that it's the bees knees for a track car.
What's your setup?
Old Aug 11, 2009 | 01:46 PM
Smurf's Avatar
Smurf
ummm ..
D16z6
Darton sleeved
FJ rods
Vitara pistons fj
supertec spings and ret.
bitmo cam
golden eagle intake manifold
and fuel rail
toga oil pump
top mount manifold
bullseye turbo s362
Old Aug 13, 2009 | 11:51 AM
fathergoat's Avatar
fathergoat
:3
In that case just get some 1000cc injectors and tune with crome. The rest of the fuel system doesn't need anything special. I do suggest you use a motes 2timer to run one map for e85 and one map for low boost on gasoline.
Old Aug 15, 2009 | 10:39 AM
Smurf's Avatar
Smurf
I was thinking of using some 1600cc injectors.
e85 usings 35% more fuel.
Old Aug 15, 2009 | 04:13 PM
fathergoat's Avatar
fathergoat
:3
1000cc should be enough for around 400whp so 1600cc would leave some headroom.
Old Aug 15, 2009 | 10:07 PM
mattliston's Avatar
mattliston
Living and Learning FTW
on regular gas, 750s should be plenty for 400whp. on E85, 1000cc injectors and a raised fuel rail line presure to 50PSI will be fine. if you are running a Walbro 255 pump, that part is already done for you (mine read 49 psi with only the walbro installed)
