Idle high on startup
Old Jan 30, 2003 | 02:31 PM
crucial Si's Avatar
crucial Si
Banned
Originally posted by ur31337
Right, that's what I thought too. I've always got something on anyways. I mentioned it at the dealer, they looked at it, said it was fine.
it says it on the underside of the hood of what it should be.
Old Jan 30, 2003 | 02:37 PM
ur31337's Avatar
ur31337
Colby
Would it be higher if the weather is cold, or if I've got the radio on, have my foot on the brake, vents blowing?
Old Jan 30, 2003 | 02:54 PM
Level_7's Avatar
Level_7
Mine idles around 1600 RPM when cold, and then idles at 750 RPM after that. The ECU will adjust the RPM to bring the engine to operating temperature within a minute or so of starting the engine cold.
Old Jan 30, 2003 | 03:20 PM
jordan88's Avatar
jordan88
when i need to adjust throttle cable, and how?
thx
Old Jan 30, 2003 | 03:48 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
thx
It's simple. It connects at the throttle body. There is a bracket that the cable attaches to with a nut and an odd looking nut. Just loosen the 12mm nut on top until you can pull the cable away from the bracket. Tighten or loosen the odd looking nut (depending on if you want to bring your idle up or down). Then, put it back on and tighten the nut again... done!
Old Jan 30, 2003 | 08:23 PM
ryewdedyet's Avatar
ryewdedyet
According to the S/M (shop manual) the idle speed for d16y5, d16y7, and d16y8 96-99 Honda Civics is 700 rpm +/- 50. So when the car is fully warmed up, meaning that the fan has come on once, the idle should be between 650 - 750 rpm.
Before you adjust the throttle cable you might want to do a simple visual inspection. There are several reasons why an idle on a car my be higher than usual. Usually it's a vacuum leak of some sort. You might want to inspect all of the hoses that are connected on your Civic or car. Even better, connect a vacuum gauge by "t"ing it to the fuel regulator hose or the EGR hose (if your car has an EGR). The vacuum reading for a 96-99 Civic when it's fully warmed up will be around 20 psi. The higher the vacuum the better.
Secondly look at the temp gauge on your cluster to make sure that is not at the "cold" level. If your engine is cold then the computer will tell the fuel injectors to deliver more fuel. thus causing the idle to raise.
NOTE: you can't really depend on the temp gauge on your dashboard 'cause it may be broken. So the best way to test your car is getting it hot by reving the engine while you're at neutral and waiting for the cooling fan to turn on. If it turns on that means it getting hot.
Third, check your ignition timing with a timing light. If your ignition timing is advanced that too will also raise the rpm.
Fourth, your O2 sensor my not be warming up. A four wire O2 sensor has a seperate wire that heats up the sensor so the car can go into close-loop faster.
That's all I can think of for now. But before you start taking things off or adjusting things on your car, it'll help a lot if you do some diagnostics / inspection. It'll ease your mind a little and will help isolate the problem.
Old Jan 31, 2003 | 12:41 AM
DCivic's Avatar
DCivic
Thanks everyone for the insights...just got the car and getting to know it.
Take care all,
Old Jan 31, 2003 | 03:51 AM
westcoaststyle
good info man... I'm impressed. :thumbup:
Old Jan 31, 2003 | 08:29 AM
DCivic's Avatar
DCivic
I will second that....
