Removing rubber mounts
Old Jan 29, 2003 | 10:38 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Default Removing rubber mounts
I'm putting in the hyper flex kit to replace all my rubber bushings in my lca's, and suspension.
since i'm becoming more and more cheap.
i decided to try and remove the bushings on my own at home.
What I am using.
Drill
Jigsaw
Flat head screw driver, and whimpy hammer.
I drill the rubber over and over again till i get it nice and weak.
Then i take the metal sleeve inside the rubber, and twist it. and pull it out.
Once I have that out. I have to get the metal sleeve around the rubber.
I whip out my friend jigsaw. take the jigsaw, and cut through metal across. Then i whip out the screw driver, and hammer under neath the metal sleeve till I can start popping it up. Once I get that. I keep hammering underneaht the metal till I get the area where i cut across off. Then I'm simply start hammering around. Til tlhe metal comes out.
I just did my first one.
1 1/2 hours for one bushing... WEEEEEEEEEEEEEEE:madfawk:
Damn it why am i so damn cheap!
Project EVA - The Track Package
Project EVA
Old Jan 29, 2003 | 11:43 PM
Outxider's Avatar
Outxider
X-Motoring
does it take as much work to insert the new one in or easier. sounds like a fun filled weekend for ya.
late
Old Jan 29, 2003 | 11:52 PM
DSC's Avatar
DSC
Long way from home
Heh. I dont think its worth the hassle.
Old Jan 30, 2003 | 03:37 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
I thought that u can torch them to get them out easier.
Old Jan 30, 2003 | 03:38 AM
wilsel's Avatar
wilsel
:thumbup: Same technique I used! Well, actually I used a pointed punch instead of a screwdriver.
And, yes it is totally worth it! Keep going, you'll be done in no time.
Old Jan 30, 2003 | 06:58 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
Default What's up?
Ha ha, have fun with those. I did sort of the same thing for the fronts except I used a hacksaw instead of a Jig. I'm too cheap for power tools. I ripped out the center sleeve, took the blade off the hacksaw, put it through, sawed a chunk out of the the out bushing shell and then just hammered it out with a screwdriver. Worked like a charm. To put the new bushings in, it's simple. Just grease the piss out of the LCA hole and the bushings and put them in a vise and push each side in. After that, grease the center sleeve and push it in.
For the rear LCA, I got tricky. I did this over at the shop so I had a press and some machines. I measured the metal outer sleeve and machined a round brass plug on the lathe to just a bit smaller and then just pushed the SOB right out. Took about 30 seconds to do each bushing. Oh yeah, the rear subframe bushing is a huge amount of fun. Good luck. Seeya.
Old Jan 30, 2003 | 09:27 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Andy I'm kicking your ass when I see you at Carlisle.
I would've worked on the car bushings. But I'm still at work (pulling an all nighter). I"ll bang through one more bushings when I get home in the afternoon.
Project EVA
Old Jan 31, 2003 | 03:55 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I still say use a press. I did and I had all of mine in and out in about an hour.
I really don't know how you're going to get the new ones in without a press.... a vice maybe? :dunno:
A lot of those are MUCH bigger than the hole.... lube it man.. lube it.
Old Jan 31, 2003 | 06:01 AM
Andy's Avatar
Andy
Default What's up?
You definately do not need a press to push the new bushings in. A lot of grease and a decent sized vice will do just fine (that's what I did to push all my new one's in). Hell, that's the easy part.
Check out my snazzy grease fittings (which I have yet to use). Seeeya.
Old Feb 1, 2003 | 04:40 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
i increased removal by 60%. I purchased a bigger hammer. >=]
Project EVA
