stock headunit/city light help
Old Jan 29, 2003 | 03:18 PM
h22akilla's Avatar
h22akilla
Default stock headunit/city light help
while i was driving listening to music all of a sudden my stock headunit just turns off. i mean the clock doesnt even show up. i'm thinking its a fuse cause i smelt some type of burning. then i noticed that my city lights werent on either cause the switch i wired them to wasnt lit. they're not wired together which gets me, maybe its just my luck. what a day. anyone have a similar problem. thoughts or help would be appreicated. thanks. oh its a 99 civic si.
Old Jan 29, 2003 | 03:25 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
double check your wiring. Sounds like you fried one. Did you have an inline fuse for the lights? That could be the problem.
Old Jan 29, 2003 | 03:37 PM
h22akilla's Avatar
h22akilla
yup just checked it out. it was the fuse for the radio clock. i guess the city lights are somehow connected to that fuse. i guess its cause the city light is connected directly to the fuse box. thanks for the help. i might try rewiring things a bit different. thanks again.
Old Jan 29, 2003 | 03:47 PM
h22akilla's Avatar
h22akilla
but if anyone knows why the city light switch went out when the fuse for the radio clock blow that would be helpful. should i try to connect it to a different plug under the fuse box
Old Jan 29, 2003 | 03:51 PM
19.3secS2K's Avatar
19.3secS2K
did you wire these yourself? If so, you probably know more about it than we do.
