suspension help
Old May 12, 2009 | 07:41 PM
dspencer24's Avatar
dspencer24
b18c ftw
Default suspension help
i just got done installing my h&R sport springs and my passenger rear is higher and the camber is worse? what could cause this. thanks for the help
Old May 13, 2009 | 07:47 AM
dspencer24's Avatar
dspencer24
b18c ftw
it doesnt make sense that the camber is worse when its higher. Also the one side has always sat higher even when i had the pro kit on there.
Old May 14, 2009 | 08:02 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
was the alignment/camber fine before you swapped springs? The fact that the ride height and the alignment are off suggests to me you might have a bent suspension arm.
Old May 15, 2009 | 10:43 AM
dspencer24's Avatar
dspencer24
b18c ftw
I had adjustable coil overs on them so i prolly adjusted them to fit right. But it could be possible that its the suspension arm , 2 years back i had to get pulled by my rear driver side suspension arm, all tho that is the one that looks fine to me.
Old May 15, 2009 | 10:53 AM
Civic2Scooby's Avatar
Civic2Scooby
bent suspension component sounds like the culprit.
Old May 15, 2009 | 01:53 PM
dspencer24's Avatar
dspencer24
b18c ftw
see thats what i thought but why would the other side be bent for also today it sounded really loose and like something was banging around ill try and take some pictures.
