odd....fast blinker??
Old Jan 20, 2003 | 06:48 AM
Duff Man's Avatar
Duff Man
Default odd....fast blinker??
I was driving to work this morning and the left turn blinker was falshing rapidly as if I had a bulb burnt out. Well I parked the car and checked it out on the outside and it started blinking normally. My next thought was that the switch was frozen but I park in a heated garage over night. I had this problem with my last car too. It could also be a short in the wiring harness of my half red/clear tails.
Just wondering if anyone else delt with this and solved the mystery
Old Jan 20, 2003 | 07:15 AM
ManInCamo's Avatar
ManInCamo
Old School Crew
Try replacing both bulbs [to make it easier (left side, front/rear)]and see if that solves it. It may just be a loose filament in one of the bulbs.
the red/clear tails have no wiring with them... they use OEM wiring, which is built into the car...
Old Jan 20, 2003 | 08:37 AM
92teg's Avatar
92teg
It might be the left reveres light. Try to change that one out
Old Jan 20, 2003 | 10:15 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
It could be as Manincamo said a loose filament in one of your dual filament bulbs. Try switching sides and see if it happens again.
Old Jan 20, 2003 | 12:45 PM
JLAudioFan's Avatar
JLAudioFan
I got the SI fever!
I've always thought that when blinkers flash fast like that, it's a sign that one of the bulbs is going to burn out soon... Dunno if that's really the case or not. Might as well replace em, not like they're expensive
Old Jan 20, 2003 | 02:28 PM
RaVen_CiviC's Avatar
RaVen_CiviC
CTR = Fun
my left blinker blinks fast when the headlights are off, and very slow when the headlights are on. and it doesnt actually "blink", it just goes on and then off. ive tried 3 different sets of bulbs and no good. next step is to test the wiring? any ideas?
Old Jan 21, 2003 | 11:41 AM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
yeh ive been havin problems with my left turn signal too lately
sometimes is blink really fast, sometimes it blinks in little bursts, and other times its fine
i have no idea what the problem is but as soon as i fix it ill let u guys know
Old Jan 24, 2003 | 10:53 AM
Duff Man's Avatar
Duff Man
well it hasn't happend since but this is like the billionth time its done this regardless of how new the bulb is.
Old Jan 24, 2003 | 01:55 PM
HeavyCivic's Avatar
HeavyCivic
Team HighRev
well i just replaced all my bulbs and everything is fine now
dont know what could be wrong with urs
Old Jan 24, 2003 | 11:55 PM
shiznattik's Avatar
shiznattik
you are probably out of blinker fluid
