cold weather start!
Old Jan 16, 2003 | 03:23 PM
jordan88's Avatar
jordan88
Default cold weather start!
hi, i have a 98 civic ex coupe, its like -16degrees outside, i left my car outside for like more than 12 hours. when i tried to start it this morning, the battery seems weak, it cracked for couple seconds, then it started, but if i let the key ignition go, it will die, but if i hold it on for littlebit longer after it had been started, it will not stall. it starts find when its warm.
also is it not good for the engine and the starter if i keep cracking on the ignition after it has been started?
thanks you!!!
Old Jan 16, 2003 | 04:22 PM
Tirod's Avatar
Tirod
prolly need a new battery...
Old Jan 16, 2003 | 04:30 PM
crucial Si's Avatar
crucial Si
Banned
oil freeze?
Old Jan 16, 2003 | 05:09 PM
jordan88's Avatar
jordan88
so if i plug in the block heater, it should be ok, rite?
Old Jan 16, 2003 | 08:15 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
if you turn the key once it's running, you're burning up the gear on your starter! :doh:
Old Jan 16, 2003 | 09:46 PM
jordan88's Avatar
jordan88
you mean when it grinds?
Old Jan 19, 2003 | 08:38 AM
derf's Avatar
derf
Spec5
at what temperature should you get a "cold weather package" i don't know the freezing point of anything ..... so -16... i've never had to start my car in that cold of weather
Old Jan 19, 2003 | 08:58 AM
DanM's Avatar
DanM
I wouldn't be cranking after it's started. Not good for the starter.
The way I see it, you have a couple options. One is to invest in a block heater. Great for cold winters (I assume you're in Canada too, my car had a little trouble starting in -16 the other day too).
The other option is to get yourself a bit of a winter tune-up. They'll do plugs, timing, maybe distributor, depending on how long it's been since your last tune, etc. etc.. You'll find it helps a lot with smoothness in the cold weather.
Old Jan 19, 2003 | 02:42 PM
jordan88's Avatar
jordan88
thx, but i dun that already
Old Jan 19, 2003 | 02:54 PM
The G2 Racer's Avatar
The G2 Racer
Want Boost!
I'm with Tirod, my car doesn't have a problem starting. Maybe a new battery?
