traction problems
Old Jan 16, 2003 | 06:16 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
better suspension will help dramatically.. i tropped .3 just from my new suspension.
your suspension i'd say needs to be worked on for better times.
Project EVA - The Track Package
Project EVA
Old Jan 16, 2003 | 07:32 AM
oc_civic's Avatar
oc_civic
mcc racing
camber kit.. you can have the best tires in the world, but if the contact patch isn't flush with the ground or close enough to it its STILL gonna suck....
Old Jan 16, 2003 | 07:48 AM
c-c racing's Avatar
c-c racing
what kind of motor mounts are you do you use solid or conventinal rubber mounts also try sway bars but before any money is involved try air pressure
10-15 psi
Old Jan 16, 2003 | 08:35 AM
oc_civic's Avatar
oc_civic
mcc racing
they also make traction bars
Old Jan 16, 2003 | 05:22 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Also better alignment. If you are dropped and not running a camber kit that means you have negative camber up front which means the whole tire is not in contact with the ground. 1 degree of negative camber is good, but anything more is bad for launches.
Also learn how to feather the clutch better. Dumping the clutch at 5000rpms and you're spinning? Maybe try 4000rpms.
But then again Nitto tire sucks anyway.
Autocross Help Page
Old Jan 16, 2003 | 05:50 PM
reddemon009's Avatar
reddemon009
i dont even launch i make my self bog down on purpose. as soon as i hit 5500 rpm the tires let loose. iam currently running 15 psi in the tires and they look like they sit pretty flush to the ground even know i do not have a camber kit. so i think i have to go with a better suspension. wat setups are you guys running?
Old Jan 16, 2003 | 07:52 PM
CivicSiRacer
Well that's your problem too. 15psi in your tires? Try running 25-30psi.
Autocross Help Page
Old Jan 17, 2003 | 07:49 AM
oc_civic's Avatar
oc_civic
mcc racing
they are ONLY sitting flush because you let out so much air.. they SHOULD sit flush full.. i would NOT say that the camber kit will DEFINATELY solve the problem.. but it DEFINATELY will NOT hurt...
do you get spin or spin and hop.. because im drag racing traction bars help eliminate that hop.. i dont know how streetable they are.. but i read an article once that talked about driving around with them on...
