v afc
Old Jan 15, 2003 | 05:55 PM
reddemon009's Avatar
reddemon009
Default v afc
does anybody know how to tune the apexi v afc v tec controller. i put it in my 96 ex turbo and the car runs like ass. it ran better w/o it. any info would help. thanks.
Old Jan 15, 2003 | 06:01 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
What's the rest of your setup? Generally you'll want to put the thing on a dyno and have someone tune it who knows what they're doing.
Old Jan 15, 2003 | 06:16 PM
j-speed racer's Avatar
j-speed racer
i'd recommend putting all the setting back to stock, such as fuel %'s, vtec switchover, etc.
if the car still runs like ass then it may not be wired correctly. if it runs good again, run it on stock settings until you can get it on a dyno.
Old Jan 15, 2003 | 09:09 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Make sure your sensor and vehicle type settings are correct.
Old Jan 16, 2003 | 03:40 AM
ManTiS's Avatar
ManTiS
NinJA
There should be no reason why the car would run horribly with that on unless:
Incorrect installation
Incorrect settings
This wasn't the so-called AFC hack/trick that you did, is it?
Old Jan 16, 2003 | 05:35 AM
crucial Si's Avatar
crucial Si
Banned
my boys b16 turbo ran better when he put the crossover at 8grand.
Old Jan 16, 2003 | 10:16 AM
92b16vx's Avatar
92b16vx
Disconnect the VAFC reset your ecu and then hook it up right and either take it to a dyno,or at least get someone with a clue to adjust while you drive around.
Old Jan 17, 2003 | 03:56 AM
ManTiS's Avatar
ManTiS
NinJA
uh....okay phillis
Old Jan 17, 2003 | 03:57 AM
ManTiS's Avatar
ManTiS
NinJA
Easier said than done. When installing a AFC, wires will be spliced and/or cut. Just re-check wiring.
